Automatic Y8 intake help
Old Aug 19, 2009
GaSSaver97's Avatar
GaSSaver97 is an unknown quantity at this point
I just swapped motors from a d16y7 to a y8. Now my question is the y8 motor came out of a automtic car and i have a 5 spd. Which means the intakes are going to be different. How would i do about fixing the idling problem...I had to put the old y7 mani on there so it would idle correctly. And as a side note i bought this motor with 90k on it and i am only getting around 300-330 miles to the tank... I should b getting more right? tune?
Old Aug 19, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: Automatic Y8 intake help
I'm betting it has to do with the difference in the IACV. I'm not entirely sure about the y7 but the y8 automatic uses a different IACV than the manual. They use different throttle bodies as well. If the y8 mani you have came from an automatic you will have to drill two holes in it to use the manual idle valve though.
Old Aug 19, 2009
GaSSaver97's Avatar
Ok so so the y7 idle valve will fit on the y8? Should i get it tuned i dont feel like i am getting enough milage or power..... this thing is a terd
LorenzoC0395
Jul 14, 2015 08:46 PM
xzykotic
Mar 22, 2003 08:27 PM
fonto
Aug 10, 2002 05:09 PM
sassy1
Feb 6, 2002 10:39 AM
ripper
Jan 30, 2002 06:45 PM
