d17a2 rebiuld NEED HELP!!!
Old May 4, 2008
arush-civic's Avatar
arush-civic is an unknown quantity at this point
I guss ill just start with the story. i spun a rod bearing in my 02 civic ex. so i want to upgrade while its torn down. i already know the rods are the weak link in the d17. i found a kit from improtcustomparts.net and it has all the seals bearings pins pistons and rods for $1500 but if i through a stage 2 cam and new valves and etc will it change the compression ratio of the lower half.... i do plan on running a t3/t4 greddy turbo kit... any other info that i need to know i would appreciate it.
Old May 4, 2008
minorc's Avatar
minorc will become famous soon enough
Re: d17a2 rebiuld NEED HELP!!!
It wont change the comp ratio if you put just a cam and springs / valves, and greddy doesn't make a turbo for our cars.
Old May 4, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
You can change the compression if you go from a dish face valve to a flat one, but with boost you're not gonna want flat faced valves.
Having never seen a T3/T4 greddy kit... mostly because they dont make them, I think you probably want to do more homework. Anyways, an entire engine rebuild kit for 1500 sounds too cheap to be true with D17 parts, considering the pistons are 450, the rods are almost 700 and you need around $700 more in seals, gaskets and bearings from honda to rebuild it all right.
Old May 4, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ full gasket kit = 150
full acl duraglide bearings = 80
700 bucks in seals gaskets and bearings? o_O
Old May 4, 2008
Jap-Euro Fusion
ACL does not make D17 bearings. You can modify D16 bearings, but there is no direct fit. Mains are 6.XX a piece, you need 8, rods are 5.xx you need 10.
you spin a bearing, you need an oil pump, thats ~50 bucks
you need a new set of head bolts or head studs, another 100+
timing belt is an automatic replacement item, may as well also put a new tensioner on it, and a water pump +160 more
New cam and crank sensors is another $80
It adds up fast.
I have all the receipts if you dont think i'm serious.
dont even forget the fact you need to have the whole block and head flushed of bearing shavings, and have the journals and crank remachined.
Old May 5, 2008
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
acl makes bearing for d17 now boiler.. just came out
Old May 5, 2008
yea boiler. im running ACL d17 bearings now!! CHEERS
Old May 6, 2008
ok so I should have mentioned I am already running a small turbo and acl makes a kit with all listed above in there hp kits for $1569. and im not using the hole greddy kit my buddy bot 1 for his si and traided 4 a fully biult si with another friend so im getting the hole kit 4 $700. and obviously the block will need flushed and some more work done and the crank will need rebalenced and worked. I no its expencive but don't no what parts to look 4
Old May 6, 2008
andyman97's Avatar
Turbo Guru
Link to this "rebuild kit" please? The one you posted is spelled wrong and even spelled correctly, doesn't point to a valid site.
Old May 6, 2008
sorry bout that its http://www.importperformanceparts.ne...pek-honda.html
Old May 6, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
"Page Not Found - 404 Error
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable. "
Old May 6, 2008
andyman97's Avatar
Turbo Guru
# 16
I wasn't aware pauter had off the shelf rods...or MLS made headgaskets...or have ever heard of toga bearings before.
Old May 7, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Yea but look what it says guys!! Duh.....
No more wasting time trying to choose the right parts for your application. Our engineering staff has done all the research and hard work for you. Plus, it's all available in a discount priced kit. Call us now to order at (603) 378-0090.
They have engineers....you guys don't know what you're talking about! ahha....
OEM TO DEATH!!!!!
BootyDo
Jun 21, 2016 03:45 PM
mac25
Aug 21, 2015 11:14 PM
tock172
Jul 21, 2015 06:25 PM
alex_nyc
Jun 16, 2015 08:12 PM
