Made a rose today
Re: Made a rose today
Get work bonus this friday so im starting to butter her up early to see if i can actually spend some of it on probably the 66 442 being its the one with the most need atm! Thread Starter
Thanx, im thinking about making them for profit. Its not that hard with the right tools. If your serious i'll pm you the photos i have.
Tools i used....
Air nibbler
Mig welder
tin snips
Variouse files
Bench grinder
needle nose pliers
Drill press
die grinder with cut off wheel
Supplies....
20 ga sheet metal
3/16" steel rod
Metal cast paint for purple
some sort of green metalic auto touch up paint for stem
tape
Tools i used....
Air nibbler
Mig welder
tin snips
Variouse files
Bench grinder
needle nose pliers
Drill press
Supplies....
20 ga sheet metal
3/16" steel rod
tape
Ok quick DIY!
Tools i used....
Air nibbler
Mig welder
tin snips
Variouse files
Bench grinder
needle nose pliers
Drill press
Supplies....
20 ga sheet metal
3/16" steel rod
tape
Draw some random patterns that resemble picture
cut patterns and clean up edges, then drill hole thru center of each pattern to same size as rod used for stem
stack each pattern on the top of the stem and spot weld each as you stack
start to stand up one petal at a time and bend to the shape you desire
Finished forming, and ready for paint!
Tools i used....
Air nibbler
Mig welder
tin snips
Variouse files
Bench grinder
needle nose pliers
Drill press
Supplies....
20 ga sheet metal
3/16" steel rod
tape
Well the first sold one my brother bought for an undisclosed amount
But i think im going to ask $50-75 range depending on volume and detail work
But i think im going to ask $50-75 range depending on volume and detail work Thread
17
Jul 23, 2015 11:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
breanna_17
Jul 21, 2015 04:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
