SRS Light problem
SRS Light problem
I have read the SRS light threads and wanted to know which parts from http://www.hondaautomotiveparts.com/ are the:
1.) SRS Unit (I assume 4 from clicable image below)
2.) Which part is the seat belt tensioner that needs to get replaced?
3.) I cant find the OPDS unit everyone speaks of. Can someone please point me in the right direction.
Thanks in advance.
Thanks in advance.
Re: SRS Light problem
Honda has extended warranty for seat belts. Is the SRS code related to the tensioner ??
just take it to the dealer. and i had the same car at one point in time and had the OPDS unit fail, or at least the diagnostics stuff at the dealer said so. you can probably get it replaced under warranty.
pretty sure he does, as his car is listed in his sig as a 2001 Honda Civic EX. if it doesnt have side airbags, then I don't know. i just know my opds unit has went bad before and i was told it could have been from having a cell phone or computer on my seat, both of which at the time i had on my seat on more than one occasion.
i had an 02 civic ex sedan a year ago that had side airbags, and now i have a 2001 civic lx coupe that had side airbags in the stock seats as well, and i have rsx seats in it now with side airbags that i'm assuming are functional because when you lean to the side in the passenger seat it'll say the airbag is off. i thought all EX models had side airbags.
I read into this before i got my car and im pretty sure all coupes and ex from 01 up comes with sideairbags...the LX and LXg dont atleast 01s and 2s
i think only the coupe in canada has them. Got a 02 lx sedan w/o them.
Wow. Thanks for all the replies. Still have not had a chance to take my car to the stealership because I have been working on remodeling my condo and can’t be without my car to transport material for more then a day.
My car does not come with side airbags. My next door neighbors 2001 Civic Ex did come with them. I guest there not installed on all Ex models.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Here is the answer:
If you have 2 plugs under your seat you do have the OPDS, one plug will be grey in color (Seat Belt minder) the other will be yellow (opds)
i have two plugs under my seat with rsx seats with side airbags. SRS light has been on since I put them in and would come back on after trying the SRS reset DIY several times. I've since just ignored it....i wonder sometimes though if my 'bags will deploy in a crash...
This is interesting:
I also have a similar issue. I have a SRS light in my 2002 civic 4dr LX (With SIDE AIRBAGS!!!). The dealer-**** states it is an "OLD History Code." They cleared it and told me "it might come back on"
The mechanic says it is a High output Load on the passenger side airbag??? Don't quote me on this exact terminology because it was hard to understand
So ofcourse the light comes back on. I take it there and now they are saying it could be:
1. SRS Unit [$415 includes 1.5hrs labor]
2. SRS Harness [$960 includes 2.0hrs labor]
3. Passenger Airbag [$890 includes 1.0hrs labor]
These prices are just for comparison in your case. They want to charge $78 to take a look and test each component for the faulty part. It will be applied to and included into the above costs.
The dealership never did mention anything to me about the seatbelts as potentially being a problem. Maybe it is something that I can inquire further next time I go.
Maybe we can ALL get this figured out. Anyone else have any input?
The dealer also stated Many times the AIRBAGS WILL NOT DEPLOY in the event of an accident due to current SRS Light being on.
Thanks again for your input and help guys!
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
SimDogg
Nov 27, 2001 04:20 PM
