My Honda
Old Oct 14, 2007
mad dogg's Avatar
mad dogg is an unknown quantity at this point
Cool My Honda
I NEED SUM ADVICE CUD ANY ONE TELL ME HOW TO MAKE MY CIVIC QUIET I WANT THE ENJIN TO HUM I CAN HERE LIKE A SLITE TAPIN IS THAT THE INJECTERS ????????????????????????????????????????
Old Oct 14, 2007
speedfoos's Avatar
Re: My Honda
First, don't type in all caps. It's irritating.
Second, we don't know anything about your car, it's setup, what mods you've done, so on and so forth. Without any information, how can we help you?
Third, come on man. Spell check and grammar. You're 27 years old. You should know how to string a sentence together without sounding like a 16 yr old kid crankin' on Pop Rocks and Dr. Pepper.
Fourth, you'd do best to take this out of your public profile now before too many other folks see it....
About Me:
i love cars jap cars im a bit like jessi on the fast and the furious first film cars carm me down.
Welcome to the site. Most of us are OK here, but you're not going to get much traction without some clear questions and background information provided first.
Old Oct 14, 2007
ciVictoria's Avatar
Re: My Honda
Maybe he has that thing...you know ricer syndrome?
Old Oct 14, 2007
mdawg's Avatar
mdawg is on a distinguished road
Re: My Honda
Hey what does the tappin mean, when its very cold I hear that noise untill the engine heats up?
Old Oct 14, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
Re: My Honda
it sounds like valve tapping to me, and even on my new 06 FG1 you can slightly hear this happen especially when at a drive-though window, but if its pretty loud & on an older vehicle then youll need to fix it, however if you cannot afford to fix it at this time
I suggest using/doing:
a thicker oil grade then your currently using right now.
BarDahl - its like a thick glue, overtime this could lead to further damage imho.
but should work.
Valvetrain, guides, seals are getting sloppy!
i hope im wrong but give the thciker oil a shot?
Old Oct 14, 2007
mad dogg's Avatar
Re: My Honda
thanks i will try some oil thanks for reply every one im new at this.
Old Oct 14, 2007
mad dogg's Avatar
Re: My Honda
on my civic it says v tec e wot the e for?
Old Oct 14, 2007
mad dogg's Avatar
Re: My Honda
im new at this thanks for advice
Old Oct 14, 2007
speedfoos's Avatar
Re: My Honda
How many miles are on the car? It's also possible that you need the valve lash adjusted if you've got a fair amount of miles (80K+) and it's never been done before.
I know my old '85 CRX was noisy as all get out until I adjusted them. Ran much better afterwards too. It's fairly easy to do as long as you have a Haynes manual to take you through it. It probably only takes about 25 minutes after you get the valve cover off.
Old Oct 14, 2007
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Re: My Honda
If there are a lot of miles on the engine get the valves adjusted. Its not that expensive and its much cheaper then buying a new engine due to lack of service. Check and change the oil on time. Spent oil or not enough oil usually leads to valve noise/wear first and becomes a progressive destroyer to anything friction related. It only takes a few miles with inadaquate lubrication to wipe out a top end.
Thicker oil is a bandaid. Basically the molecules in the oil are bigger to take up more space in between the friction surfaces. If you need a valve adjustment it may make the noise stop but if the lower end is still tight you may do more harm than good.
Old Oct 14, 2007
mad dogg's Avatar
Cool Re: My Honda
my car runs sweet but every so often it misses any tips ?
Old Oct 14, 2007
CivicHatch9one's Avatar
7th gen old timer.
CivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond reputeCivicHatch9one has a reputation beyond repute
Re: My Honda
dang you post alot. for just joining.. misses how? maybe you need a tune up you got to explain more about whats happening. we cant see the car.
Old Oct 14, 2007
brent_01civic_e's Avatar
brent_01civic_e is an unknown quantity at this point
Re: My Honda
do we have trolls?
Old Oct 14, 2007
02fpcivic's Avatar
Re: My Honda
Change the plugs. Mileage?
Old Oct 14, 2007
TRIZ's Avatar
Re: My Honda
I'm so confused with this thread...
Old Oct 14, 2007
greeen01civic4d's Avatar
Re: My Honda
ur not the only one triz
Old Oct 14, 2007
Re: My Honda
get the valves adjusted. vtec-e is economy kind, for better gas mileage, not power.
Jessica Leung
May 5, 2015 05:12 PM
carid
Apr 30, 2015 07:00 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
