Left engine mount busted. (pics)
I had to take off both the upper left and lower left mount so I could slip off a couple belts, and I noticed that this thing is trashed. I couldn't even insert a socker wrench because it's bent up. The previous owner did something to it, but I don't know what. It drives excellent, but the engine moves back and forth in 1st gear if I don't feather it. Why do you think the lower mount would bend and break?
As for function, it doesn't seem like it does a whole lot. The screw goes into the rubber inside the bracket and it has free movement--so it doesn't stabalise the engine in any way. Should I even bother replacing it?
Re: Left engine mount busted. (pics)
i would advise it... it makes the car a little torqueier.. if thats a word.. they're not that expensive.. but u would have to get it iff and tat sounds like it ma be a problem
I think it's as simple as taking the A/C compressor off, then behind it is the aluminum piece the bracket is attached to.
I guess you didn't notice but I already have the bracket off since i'm in the middle of driving belts, timing belt, water pump change. (105,000)
mikemc422
Aug 9, 2018 05:41 PM
GH04si
Apr 15, 2015 08:13 PM
streetglower123
Apr 12, 2015 10:56 AM
