Can't get pulley bolt off. Argh!
Old Jul 14, 2007
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
I'm planning on doing a DIY for the 96-00's with pics, but it's at a stand-still since I just can't take this thing out. First off, I've got a 50mm pulley holder. It doesn't help much though when you break socket extensions--I mean this thing is on tight! I didn't think it would be such a hastle. Am I even turning the bolt the right way? It should be counterclockwise right? Also, does Honda over-torque it so that you don't mess with it?
I read that I shouldn't use a socket extension because they will break, and that's true, but with the pulley holder in place it's too deep for even a deepwell socket, or am I wrong?
Old Jul 14, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Can't get pulley bolt off. Argh!
deepwell impact socket, on a breaker bar, then slip a 5' pipe over the breaker bar handle. Remove the bumper so you have room, then put the pulley tool directly on a 1/2" ratchet handle, and wedge it between the control arm and the axle.
lean on the 5' or longer pipe until the pulley comes undone. Its not cranked on there so you cant get it off.... you gotta realize how much torque the motor puts out.... and that bolt has to stay on there tight no matter what.
Old Jul 14, 2007
Will a 1/2 inch breaker bar work, or will I need a 3/4th's? I'm worried the breaker bar will will break. (No pun intended)
Old Jul 15, 2007
EM2 Shinobi's Avatar
EM2 Shinobi is an unknown quantity at this point
man i dont mess around with crank pulley bolts anymore lol i bought a 720 ft lbs impact, waps the b*tch off like butter
Old Jul 15, 2007
I bought an ingersoll rand 231G. Max tourque is 450 ft lbs forward and 500 back. 4.2cfm. This should work right? I have to wait for monday for the air compressor.
Old Jul 16, 2007
Removed it pretty easily. I bought a 24" 1/2" breaker bar, a 17mm deepwell socket (non-impact), and a 4 food pipe. The tools were from autozone. I had to take the bumper and washer resovior off to get room for leverage, but it worked.
It's very important that the socket stays perfectly straight in the 50mm holder tool, any tilt will strip the bolt. I placed a metal piece below the breaker bar holding the 17mm socket so it no longer tilted downward. (I was pushing downward thus the whole setup wanted to go downward)
SLOW AND STEADY.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Smokahontas123
Jul 22, 2015 10:07 PM
muttleytm
Jul 14, 2015 05:31 PM
manfredww1
Jul 14, 2015 10:24 AM
ballmich
Jul 9, 2015 11:59 AM
