Ignition wire....
Old Mar 6, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Ignition wire....
Hey guys, just a quick question. The instructions say run one wire to 12v, one to ground, and one to the ignition. Any help will be greatly appreciated. Pics would be awesome... Thanks in advance...
Old Mar 6, 2002
avenger's Avatar
avenger is an unknown quantity at this point
what are you installing?
Old Mar 6, 2002
Mokushi's Avatar
A varad led. It just looks like one of those led's for an alarm. I'm installing it just for the look, so people won't be as tempted to take my stuff.
Old Mar 6, 2002
Noodle's Avatar
Noodle is an unknown quantity at this point
I did one of these with my old integra. I found a fuse labeled "alternator" and that seemed to work for the hi/lo wire. For the negative wire, I loosened one of the screws holding the rear view mirror to the car frame and shoved it in the gap and then tightened it. As long as it touches any metal part on the car, it should be ok. The 12V wire I connected to one of the other fuses I connected to the clock. If there is no clock fuse, look for a function that always on even when the key is off. Anyways, hope this helps. Try to connect the scanner to equipment site of the fuse and not the power side but then I just attached it wherever.
The fuse box in the integra was underneath the steering wheel. You might have to find an alternate source for our civic. Haven't had time to look around much.
Old Mar 6, 2002
cro2k2civicla's Avatar
cro2k2civicla is an unknown quantity at this point
I have to give it to you Noodle that is one Ghetto set-up you have there....
<< For the negative wire, I loosened one of the screws holding the rear view mirror to the car frame and shoved it in the gap and then tightened it. >>
Mokushi if your going to do it yourself, atleast wire it correctly and go down to the nearest auto zone or whatever and get the parts you need.
Peace
Old Mar 6, 2002
Mokushi's Avatar
Anyone have a pic of the ignition wire that the instructions are referring to?
Old Mar 6, 2002
zero's Avatar
zero is an unknown quantity at this point
Why don't you just do a hook up to a switch so you can turn that sucker on and off if you want to.
E-mail if you need more help, shiet if you live in the bay area, I'll install it for you.
[IMG]i/expressions/moon.gif[/IMG]
Old Mar 6, 2002
Mokushi's Avatar
I thought about a switch, but I don't want to have to flip it on/off every time I get in/out...
Old Mar 6, 2002
Noodle's Avatar
Yeah, well this was my first try at it and plus it was on an old car. Never had a problem with it though. All the stuff on my civic is done nicely though. I think...
&lt;&lt; For the negative wire, I loosened one of the screws holding the rear view mirror to the car frame and shoved it in the gap and then tightened it. &gt;&gt;
Old Mar 6, 2002
Daniel420's Avatar
Daniel420 is an unknown quantity at this point
i have one of those Varad LEDs. Put it on my real alarm... it's pretty bright... I can take a pic tonight if you want.
danace99
Oct 17, 2015 02:51 PM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 22, 2015 06:20 PM
Donahue
Sep 9, 2015 05:55 PM
