A/F Guage problems
Old Feb 22, 2002
N20Saturn's Avatar
N20Saturn is an unknown quantity at this point
A/F Guage problems
I've got my Autometer A/F gauge installed today but I'm having problems. When I turn on the car the gauge displays one led at the lean/stoi. line and one that flickers at the richest point of the gauge. This happens when the car is off with the key in the auxiliary position and changes as well. Also, when I turn on my lights the gauge jump up to about 1/2 of the way in the middle of stoi. Then will also change when I turn on my high beams and turn them back off. I cut into the purple wire from the pcm port under the steering wheel. I was thinking that was the right one, but I'm not too sure now. Does any one have any suggestions?
Thanks,
Josh
Old Feb 22, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Try running the purple wire into your engine compartment and hooking it up to one of the wires on your O2 sensor. I'm not sure which one though.
Old Feb 22, 2002
blouisgod's Avatar
Life Begins > 6800rpms
where did you mount the gauge????[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 22, 2002
N20Saturn's Avatar
The wire I connected it to is SUPPOSED to be the wire that comes from the sensor through the firewall.
I mounted it directly in front of my other gauges on top of where the steering wheel is attached...doubt that makes any since but that’s where I put it.
Click HERE to see what it's doing.
Thanks,
Josh
Old Feb 23, 2002
AEMcivic's Avatar
So, does the gauge move at all when you rev the engine?
I've installed a few of these and I've had that problem once. What we did was tap into the wire coming from the O2 sensor in the engine bay. For some reason, when we tapped it closer to the sensor, we got a better reading and it worked.
Old Feb 23, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
i mounted my gauges in my "a" pillar ..... ill post pics soon
Old Feb 23, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
How many wire come from your O2 sensor? 4? You probably got the wrong wire.
tylerginevan
Apr 27, 2015 12:29 PM
Aznnp77
Jan 6, 2002 08:41 PM
antidote11
Jan 5, 2002 10:40 PM
LX2slow
Dec 20, 2001 08:33 AM
Jhonda
Nov 9, 2001 09:48 PM
