High Octane in civic
Old Dec 26, 2005
  #31
RangerMan's Avatar
RangerMan is a jewel in the roughRangerMan is a jewel in the roughRangerMan is a jewel in the rough
I'm drivin the only Acura that recommends Regular. The rest premium.
Old Dec 26, 2005
  #32
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
Originally Posted by A03
Most people seem to claim that lower octane will provide the most power out of wimpy engines. You may not make as much power on higher octane fuel, but even racing gas isn't going to hurt anything.
no it won't hurt the engine, but if your compression is stock, then running higher than 87 octane have the same effect of detuning your engine. a higher octane either slows the rate of burn and/or increases the difficulty of lighting the gaseous mixture.
gas burns faster under higher pressure. since the vic is a low compression motor, unless you have a tool to manipulate the timing spark to match the high octane burn speed, the detuning is unavoiable with using higher than 87. sure you can slap in a MSD unit and such, but even that won't do crap until you are at the very top end which has to to with M.O.D (motor octane number) which is a representative of high-speed, high-load knock resistance, and even then doing a small this-and-that to use high octane gas won't do shhit to your lap times even with a timing modification.
R.O.D (research octane number) is the spec for low-speed, low-rpm knock resistance, and our cars are specifically developed at honda testing grounds to use the most efficient gas possible for the ROD of our low compression engines. 87 is what'll put the most power to the ground for street driving. track days sure put in 114 octane because you're whipping around the track at full speed on the top end, but for any situ but, use 87
the higher-octane effect of detuning is minimal and won't kill your engine. but you're definitely wasting money.
Old Dec 26, 2005
  #33
pon55's Avatar
I would suggest that you guys get your girl or someone to go fill up you car and them try to guess if it has reg,hi or super?
Old Dec 27, 2005
  #34
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Originally Posted by gearbox
well i tried 93 vpower in mine once and the car felt like it was gonna die. the gas mileage was so bad I used up the whole tank in a couple days of hard driving. switched back to mobil regular and its fine. I used to use 89 with my modded motor but now that its stock I just use 87. I think as long as the car is in proper tune, 87 will work fine. maybe your car is running too rich like most factory hondas? btw i do have exhaust and ported tb which may lean it out enough to cancel the stock richness. i would love to see an a/f curve on the dyno if you get a chance. it might answer some questions. maybe even a compression test. believe it or not, i've seen stock d17s have different compression, sometimes +/- 35psi stock!
Hmm... not too rich. I have my own exhaust gas analyzer, and it looks perfect.
I may do a compression check and see where the engine is at. But mine DOES indeed run better and smoother on 91 here. This is odd. Like I said before, my last Honda hated super, ran like crap. My Milled 77 Accord ran fine on damn near anything at all. Ran the same no matter what brand or octane I tried in it. I miss it.
Old Dec 27, 2005
  #35
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
I put 89 octane in my dad's 1998 Oddysey with 180000km and it runs alot smoother. I'm gonna try 91 next time.
Old Dec 28, 2005
  #36
familycar's Avatar
i have recently switched to 91 as well. i have noticed a better idle nad a easier smoother powerband. i also pick up a few ectra miles per tank. its really not htat bad considering your paying what and extra $2.50 a tank. i run iridium plugs and have full exhaust and cai. soon after my headwork ill will probably run 100 oct because i will be bumping the CR by milling the head and running stg2 crower cam set up. oh yeah i usually only run chevron or shell. in socal they seem to be the best gas from my experience.
Old Dec 28, 2005
  #37
tinman's Avatar
So you notice the same thing... I also use iridiums, and I also get a few more MPG. On 91, that is. I KNOW it's not in my mind.
Old Dec 29, 2005
  #38
familycar's Avatar
no its not in my mind i honestly check my milage every tank. and i do get a couple more mpg's and a smoother idle and it just feels like it runs smoother all together
Old Dec 29, 2005
  #39
tinman's Avatar
Oh, it DOES run smoother, and has more zip to it. I wonder if it does have something to do with the gas we get here, maybe even the additives.... IF it's not octane. But I have to tell you, I drove a 4 banger volvo sports sedan in Germany on 104 octane. Man, that car ran GOOOOOD!! Especially on the Autobahn.
Old Dec 29, 2005
  #40
familycar's Avatar
i have to run 87 in my truck. all i have doen to it now is intake and exhaust and a lower temp thermostat. it doesnt make a bit of difference in my truck but my car idefinately notice the difference
Old Dec 29, 2005
  #41
CivicSF's Avatar
junked up injectors don't have to do with octane. has to do with detergents in the gas brand.
Old Jan 1, 2006
  #42
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Where are you getting your gas from?
Is is from a place that gets good business?
Old Jan 1, 2006
  #43
tinman's Avatar
I Get gas from 76 or Chevron around here. Mostly 76. The station is ALWAYS busy, so there's usually fresh gas. Chevron does not run as smooth in both my cars, and mileage goes down. Octane does not matter. But I use it if the 76 has a long line and I'm in a hurry.
Old Jan 2, 2006
  #44
jackburton's Avatar
Try an exxon, sunoco, or mobil and see if the higher octane still makes your civic run better. A freestate in my area gets tons of business but their gas still sucks.
Old Jan 2, 2006
  #45
MajinB's Avatar
Drunken Master-7thgen Ninja
you live in la. smog probs maybe the cause of you needing 93. when i use premium in my car i get like 20mpg vs 40 on regular
Old Jan 2, 2006
  #46
do any of you use fp60 with your 87? it doesn't raise octane but it does kinda make the gas run like higher octane if i explained that right.
Old Jan 2, 2006
  #47
tinman's Avatar
I'll give that a shot, just to find out. Even though there are none of those anywhere near me. But what the hell.
Oh, Gearbox, no I don't.
Old Jan 2, 2006
  #48
you really should try it out. it gave me 5mpg more in the city but i do need to recalculate all this since the car is back to stock and i'm using 87 now..
Old Jan 2, 2006
  #49
tinman's Avatar
I'll try it next time I see some at the autoparts store.
Old Jan 2, 2006
  #50
www.lubecontrol.com quality can't be bought in stores...yet. the tests speak for themselves.
Old Mar 18, 2006
  #51
Johnold's Avatar
Johnold is an unknown quantity at this point
MOBIL 93 premium octane gas all the way baby! been using it for a year now no problems. thank god.
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 06:58 PM
godka0s
Bolt-on Engine Performance
Nov 8, 2001 07:16 PM
