Tach for youre dx!!!!!
my DX came with A/C....the only thing apart from the gauge cluster that the DX doesn't have it's Power Windows,Locks, Cruise...just stuff for the lazy people[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
For you people wanting to install an aftermarket tach in your car!!! I'm not sure about whether or not the dash cluster on the DX has the needed wire or not, I Have an EX. Someone was wanting to know about hook up an aftermarket tach and still use the original? There is an additional tach sensor by your battery. It a little plug mounted right next to your battery. Its for techs to use to cheack the actual RPM's. You will have to run taht wire through your firewall to your dash, but that is a seperate wire for your tach that will not interfere with your stock tach!!
<< For you people wanting to install an aftermarket tach in your car!!! I'm not sure about whether or not the dash cluster on the DX has the needed wire or not, I Have an EX. Someone was wanting to know about hook up an aftermarket tach and still use the original? There is an additional tach sensor by your battery. It a little plug mounted right next to your battery. Its for techs to use to cheack the actual RPM's. You will have to run taht wire through your firewall to your dash, but that is a seperate wire for your tach that will not interfere with your stock tach!! >>
Calm down [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
As for our civics, I couldn't tell you whether or not it will plug right in, or if you'd have wire it for the tach sensor.
<< Jeff let me know how the swap went or goes? i also have a 2001 dx automatic sedan and am interested in doing the swap. >>
i'm assuming you're just doing this swap cuz you want to see a tach needle go up and down? hee hee...sounds like a few of you automatic guys are trying to do the swap...ah well whatever floats your boat.
hey Im at the final point of doing the swap because There is a tach wire inside our cluster connectors. Its a blue wire on pin 13. I even spent all day yesterday reading my honda service manuel and going through the cluster wires and they all check out fine =0 the only problem now is what cluster do we buy for our dx's . There are two different cluster one is made by NS and the other is made by Visteon on this link
link
So im stuck till I can find this part out. I will let you guys know through as soon as I get it working =)
link
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
NROD315
Sep 23, 2015 03:46 PM
MamaBear2015
Sep 15, 2015 09:35 PM
2001, aftermarket, auto, civic, cluster, disconnect, dx, honda, hook, odometer, put, si, swap, tach, tachometer
