cant take oil pan off, help
Old Jul 4, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I unscrewed all visible nuts and bolts that hol it, it's not comming off!
Also I noticed, my oil pan made out of aluminum and uses a paste, rather then "normal gsket".
Is there a special technick I need to use? Tools?
Please help
Old Jul 4, 2005
streetglower's Avatar
There should be a few corners of the oil pan that you can pry on with a pry bar, that is the only way it will come off. After a few prys in each of the corners, it should come loose. And the gasket is a liquid gasket. before you install the new one, make sure to clean off the old surface on the block and the oil pan, and install a bead of gasket around the pan and reinstall. Make sure to let it sit for 30-60 minutes before you fill with oil. Then check for leaks.
Old Jul 4, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
aluminum is better, the lx models have a plastic one.
Old Jul 4, 2005
Thx, I will try it now again with a pry bar
Old Jul 4, 2005
tacheon's Avatar
tacheon is on a distinguished road
Where are you getting this information from? The oil pans are all made of stamped steel.
Old Jul 5, 2005
Yeah, its off now!
I used mini-pry bar, as advised, and pulled it off corenrs. It came off, but the hell, it was difficult, it did not want to let go..it was holding to the cylynder block as mother to her child...
Old Jul 5, 2005
Shifty's Avatar
hmmmm......what are you smoking.....lol. My engine wouldve blown by now since ive ran over a bunch of road kills with my oil pan so i highly doubt its plastic
Old Jul 5, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
where do you get this compound to make the new gasket? And autoparts store?
Old Jul 5, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
walmart has it, autozone, and oreilly
Old Jul 5, 2005
Yep, auto parts store..
Also it was pain in the butt to put back on, but its finaly done.
The most difficult part if the project so far..
Old Jul 5, 2005
tfnaaf's Avatar
BLDNPSI Mod
Honda sells a REALLY good silicone its called honda bond as i recall. Think it was retail like $15 a tube and works REAL good!
and BTW LX's have stamped steel oil pans.
SidCivic
17
Aug 23, 2015 03:14 AM
mrwhos
Aug 11, 2015 02:03 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
