Check engine code
Old Feb 16, 2005
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
Check engine code
Someone know a easy way to get out a check engine code without the datelink ??
Old Feb 16, 2005
C2i0v0i1C's Avatar
SuperMODrizd
autozone i think, o **** i dont know if u have one of those
Old Feb 17, 2005
Dark2k1's Avatar
Autozone... ??? What is it?
Old Feb 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
its a car parts store, u prolly dont have one
Old Feb 17, 2005
streetglower's Avatar
Just go to any auto parts store and ask if they will check your check engine light. Most do it for free. Otherwise buy a OBD II scanner.
Old Feb 18, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
So is it just the older gen civs that can use the paper clip method and count the blinks?
Old Feb 19, 2005
I am not sure what that means, but you need a OBD II scanner to find out the code.
Old Feb 19, 2005
tacheon's Avatar
tacheon is on a distinguished road
You could read the codes off some older honda vehicles by using a jumper on a terminal and counting the blinks off the dashboard. Unfortunately, its no longer an easy task to do on the newer OBDII Hondas. And as far as I know, nobody checks codes for free in Canada either, Dark2k1. You will need to buy a scan tool. You can get a cheap one which reads codes/clears codes only for around $70 on ebay. If you use it more than once, it should pay for itself. What irks me is that it's really trivial on some of the new Chrysler vehicles. Just hold down the odometer button while you turn the key and all the codes are displayed on the odometer display. They just got to make it difficult for us on the Honda.
Old Feb 20, 2005
Dark2k1's Avatar
Ok thank.. I'll buy scanner tool one day...
Old Mar 27, 2005
chaseman1978's Avatar
chaseman1978 is an unknown quantity at this point
anyone know how to check engine codes on a obd 1 on a 94 civic ?
Old Mar 27, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
take NEG WIRE off for 5-10mins and put it back together
Old Mar 27, 2005
buy a OBD1 scanner
Old Mar 27, 2005
tacheon's Avatar
A scanner is not required to read codes on a 1994 Honda Civic. Furthermore, pulling the battery cable doesn't help you diagnose anything. You can locate the check connector under the passenger side kick panel. It's a grey 2 terminal plug near the ecu (wire colours are black with white stripe, the other is red with black stripe.) Jumper the terminals using a piece of wire or a paperclip. Turn the ignition switch to the II position, but do not start the car. You can then count the blinks on the check engine light on the dash. The short blinks add up to form a digit from 1-9, seperated by a pause, then the subsequent digit is read in a similar manner. A long blink are values of 10's which can add up to form 10, 20, 30, etc, before the ones digit is rapidly blinked. You must then find a reference to help you figure out what the code numbers you retrieved mean.
Old Mar 27, 2005
I think a scanner would be easier.
mistermenphis22
Apr 3, 2016 08:06 AM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
