VAFC II Tunned people
Old Oct 24, 2004
K20A_Wanabe's Avatar
K20A_Wanabe is an unknown quantity at this point
Ok i have a 2002 EX with AEM V2 intake Skunk2 Exhaust HP headers and hi flow cat. I was wondering when you got your car tunned when you step on it is it supposted to be in ideal or lean or rich ? Before my car ran at rich so i set it up so it would run ideal and after 6 grand it starts going rich untill i switch gears. And when your just driving normal whats the a/f supposted to be at ? When my car ideals it sits at rich and doesn't move but i don't know if thats because i have no back pressure.
Thanks for your help guys.
Old Oct 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Is that a dent in ur car if soo that thing is big...
Old Oct 24, 2004
It should be closer to the ideal fuel ratio 14.7 I believe. Mine was a flat line around 14 when they were done. Before it's usually curvy. Ideal means you're getting the proper mixture or air and fuel, which the engine works best at. It all depends. Some people have subtracted fuel to reach the ratio, while others have added fuel. In each case, you will gain a few hp.
Old Oct 24, 2004
well i took away like -5 through the hole band and my car goes from rich ideal to lean ideal then back to rich ideal untill i switch so is that good or should i tune it a bit better ? Is it supposted to be just sitting straight up the needle that is?
BTW that isin't a dent.
Old Oct 24, 2004
If you have an a/f gauge, those are innaccurate. You need a wideband o2 to actually see the effect. And this is all wide tuning btw. Narrow throttle doesn't matter much. Here read my dyno if you still don't understand. I have settings posted as well.
http://www.7thgencivic.com/forums/sh...d.php?t=178670
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
ThatGuy913
Sep 28, 2015 05:35 PM
hatch90
Sep 3, 2015 08:45 AM
