Check Engine Light HELP!!!!!
Old Sep 9, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
My car is throwing off this two codes, when I scan them.
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P1298 Electric Load Detector (ELD) Circuit High Voltage
Anybody know how to fix it???
Car is in Safemode I think. It is blocking me going over 3.5rpm
Have stock manifold + cat (LX).
Old Sep 9, 2004
Rufus's Avatar
I know there are a few real techs out there. The ELD is beyond me.
Old Sep 9, 2004
Oh boy. ELD is electronic load detector that tells the alternator to turn on and off. The MAP has to do with intake airflow. If it's throwing codes, you may need to simply (or not so simply) replace the sensors.
Old Sep 9, 2004
civic01vtec's Avatar
are you sure that it isn't a P1108 ???
Do you have a Missing Link installed ???
The reason i ask this is b/c your stock MAP sensor is seeing boost.........this is the cause for the high voltage.
Old Sep 10, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
you think if I replace the sensor it will let me get out of save mode or whatever? right now the car won't go over 3.5rpm and keeps on dieing off on me (air/fuel gauage = staying rich). also about the ELD, is it my alternator going bad???
Circled one. Found this pic from LONNNG ago.
Old Sep 10, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I don't have anything install on my car. So i don't think it could not be P1108 - Barometric Pressure (BARO) Sensor Circuit High Voltage.
Old Sep 10, 2004
Chances are you need a new sensor. The car is in safe mode as long as the cel is on. Need to make both those codes disappear first. ELD is related, but not part of the alternator. Optoisolator posted a thread about that a long time ago.
Old Sep 10, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I will try replacing the MAP sensor tommorrow. You think that i can get a MAP like autozone / adv auto??? Or I have to go back to dealer?
I did found the threat that Optoisolator made for ELD, but it doesn't really tell me anything. Most people that is having problems with ELD is running heavy stereo and I am not.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
