Does the engine clear the tranny
Old Apr 20, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
When pulling the d17 from an 01 civic with a mt does the engine clear the tranny on the way out or do i have to bring the tranny out with it...only swaps ive done are on GM cars and am new to the honda swap game...sorta Little help would be appreciated
Old Apr 20, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Re: Does the engine clear the tranny
Since you are disconnecting the tranny from the block all you need to do is slide the tranny over a little bit and you will have no problems. I speak from experience.
Old Apr 23, 2004
great man thats all i needed to know appreciate it
Old Apr 23, 2004
cryption's Avatar
2003 Nissan Frontier
ibtl
Old Apr 23, 2004
screw it it was just easier to pull the whole damn thing much less work HAHA LOL thanx though
Old Apr 23, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
Thats what I wound up doing. I spent more time trying to figure out how to pull the engine without the tranny then I did just pulling the damn thing out with the block.
Dober has a good DIY in another thread though. Hopefully a moderator or someone can add it to the DIY section as this topic has come up multiple times.
Old Apr 23, 2004
Civicious's Avatar
Here is dober's post:
Originally posted by dober
Here's a general idea on how I did it. This is assuming you've already removed your intake/air box.
Detaching the tranny from the block
1.) Remove battery tie down, battery and battery tray (little metal tray held on with 4 bolts)
2.) Remove the ground wire from the bracket on the tranny
3.) Disconnect the slave cylinder line from the same bracket on the tranny
4.) Disconnect the shift linkage from the top of the tranny
5.) Disconnect the sensor on the top of the tranny (think it's the speed sensor) and the sensor towards the back of the tranny
6.) Remove the starter
7.) Remove the 4 bolts and tranny bracket holding the tranny to the passenger side upper motor mount
8.) Drain tranny fluid
9.) Jack up the car and separate the ball joints so you can remove the axles
10.) Loosen all of the tranny bolts that attach the tranny to the block
11.) Secure the engine with a lift or a jack
12.) Remove the bolts attaching the tranny to the lower front and rear motor mounts
13.) Remove all of the tranny bolts you previously loosened
At this point you should be able to separate the tranny from the block. Slide it over to the left and secure it so you can start pressure plate and disc removal.
To uninstall the pressure plate and disc
1.) Remove the 12 point bolts around the outer perimeter of the pressure plate
2.) Remove the pressure plate and disc
3.) Place the new disc against the flywheel and push the alignment tool through the center of it to ensure that it is lined up
4.) Slide the new pressure plate over the alignment tool and use the 12 point bolts you removed earlier to lock it down. You might want to use loctite on these bolts and make sure you torque them to spec.
5.) Remove the alignment tool
6.) Use needle nose pliers to remove the old throwout bearing from the tranny and install the new one using assembly lube
7.) Since the tranny was secured off to the side, unsecure it and slide it back in place. Be patient with this step it helps to have someone turning the crank at the crank pulley when trying to line it up.
Of course you will need to do everything in reverse order from above to reinstall the tranny. Don't forget to fill the tranny with new Honda tranny fluid.
Old Apr 23, 2004
Your Parts Guy
Thanks man I should've taken pics
I just picked up my 02 tranny with 11k miles on it so I'll take pics when I install it.
Old Apr 23, 2004
Civicious's Avatar
No problem man! I thought of taking pictures when swapping my motor but I kept having to wash my hands everytime I wanted to use my camera so I gave up on that.
Let us know how your tranny swap goes. If you take pictures and make a DIY that would be cool too!
Old Apr 23, 2004
Ive come to a stopping point im not doing a tranny swap but an engine swap and using the same tranny...anyone have any suggestions on how to get that damn flywheel off please help
Old Apr 23, 2004
Civicious's Avatar
The new engine I bought came with one so I did not need to replace mine.
Didn't you buy a Honda Civic service manual?
If not I can look at mine when I get home this evening. I'll post up how to do it unless someone beats me to it.
Old Apr 23, 2004
screw it found another flywheel at my local salvage yarfd and ran to pick it up i dont have the time to screw with that thing ...engine must be in tonight!!! Alls well tranny is on and shes goin back in now thanks guys for the help
Old Apr 23, 2004
Civicious's Avatar
Well I didn't forget, I was going to look it up this evening. I'm still at work!
I know how you feel though. You want to have that bisch back together as soon as you can. I was the same way when I did mine.
Sorry we couldn't help you more,
Good luck!
Old Apr 23, 2004
Your Parts Guy
I answered him in his other post..guess he was impatient?
Old Apr 26, 2004
I am impatient its ok though. Im not normally that way but the car had to be done that day...i didnt have any time to waste..had to go back to ork the next day...but you guys did help out a lot thanx
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
MajTom
Jun 2, 2015 11:48 AM
bo_red
May 26, 2015 07:25 PM
Jigee
May 9, 2015 11:18 AM
