DIY front strut tower bar?
Old Mar 29, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
as you probably know with my DIY intake, i like saving money and making things for my car instead of buying them. yeah im a cheap @ss but what the hey, its fun to make stuff
my friend with an integra GS was gonna make a trunk brace out of a aluminum bar (like a rod except its a cubical rod that is hollow) and bolt each side to either side of the trunk floor where some suspension parts are.
could you do the same and use that piece of aluminum to make a front strut tower bar?
Old Mar 30, 2004
OniChi's Avatar
OniChi is an unknown quantity at this point
It's been done before, they welded hollow steel rods to the strut tower area. made their own front struts... not sure how it handled but it was done before.
Old Mar 30, 2004
skarteez's Avatar
^^^ any more info on that? did they actually weld the bar directly onto the strut towers? or fabricate the places for bolts?
Old Mar 30, 2004
clownprince's Avatar
Ricerus Maximus
It could be done but the only forseeable problem with it is intake clearance issues. Most bars either rise up off of the strut towers and then go across or curve around the intake. Braces made out of tubing would be better suited for other areas of the car such as the rear and middle.
Old Mar 30, 2004
TeLLy's Avatar
Yes, it's an Acura EL
You could go RSX style and fabricate a bar that bolts onto the firewall as well as the strut tower bolts. That way your design would clear any kind of intake you wanted to put in (assuming your current intake design mimics the AEM/Injen/K&N)
Old Mar 30, 2004
skarteez's Avatar
Originally posted by clownprince
It Braces made out of tubing would be better suited for other areas of the car such as the rear and middle.
what you mean? thanks!
Old Mar 31, 2004
skarteez's Avatar
any more info?
i need help guys, ill make a DIY if this all works out. please???
MN-02-CivicEx
Jun 25, 2015 08:32 PM
civicR2k1
Dec 3, 2001 05:35 PM
CapYoda
Nov 20, 2001 10:36 PM
jessepimpride
Nov 13, 2001 05:59 PM
2Hondaz
Nov 8, 2001 11:00 AM
