check engine light HELP
Old Dec 11, 2003
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
i have had my cat gutted for about 4 months now and as soon as i did it my check engine light came on. is there any way to get this check engine light to go off.. someone told me o2 bungees but i never heard of them or found them. any help is appreciated b.c my car has to be inspected next month guess i might have to buy another cat
Old Dec 11, 2003
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
if you gutted your cat then it may be your o2 sensor telling the ECU somethings up. a MIL Eliminator or a o2 sensor simulator will trick the ECU into thinking you have a cat. But u said u have an inspection? Im guessing this is a smog inspection? you wont pass with a gutted cat
Old Dec 11, 2003
robbclark1's Avatar
Retired suspension supermod.
What? Why did you gut your cat if you did not know the repurcutions?!?!?! Of course you are going to get a check engine light! Why? Because your O2 sensor says you are running ULEV anymore. If you want to to get rid of it you need an o2 simulator. If you have a tailpipe test, then you might not pass. If they plug into OBDII then you just need an o2 sim. If you want to know what an o2 simulator is then search.
Old Dec 11, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
remove ECU fuse
put key in and turn to ACC
remove key
put back in ECU fuse
start car.
light is now gone!!
Old Dec 11, 2003
they dont do tail pipe they plug it up to your obdII... well if i take the fuse out and do the key thing the light will prob come back on in a couple of minutes
Old Dec 12, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Here in GA if your check engine light on you automaticaly fail the test.
Old Dec 12, 2003
dj02's Avatar
this is what u need link but for that much money u can just get a new cat.
Old Dec 12, 2003
atl01's Avatar
So all you do is plug your 02 sensors into that and problem gone?
Old Dec 13, 2003
dj02's Avatar
u got it!
Old Dec 13, 2003
acidbaby's Avatar
The Beez Kneez
search man a new oem cat is 800$ da da dammmmm i figured that out after i gutted mine but o well.. you can get an 02 simulator from wannabefast he makes them shipped for like 30$ or something like that just send him a pm yo!
oh yea and here is this pic for absolutly no reason at all
Old Dec 22, 2003
Crackhead79's Avatar
Lightbulb MIL eliminators and O2 simulators
Got mine today from BigJoshRacing.com (MIL Eliminator / O2 simulator) and installed it. So far I hav enot had the CEL come back on. I have a Hi-flow cat and a header with the Magnaflow cat-back system. Just amazing I may add. The sound and performance is just wonderful. For all you doubters, JUST GET IT! Anyhow, reset my ECU many a times by diconnecting the battery and then it came back about 15 or so minutes later. It was because of the lack of the cat. The O2 sensor said something is wrong with my cat. Funny, there is no cat anymore. Ha, ha. Your owners manual even says if the CEL comes on one of the main things is your emission system to check. So, whether driving with your CEL is bad or not, which it shouldn't hurt but I hear the ECU steps down your fuel mapping if you do-you should invest in one of these. Now I will have to see if I need a VAFC controller to pass emissions even with this ULEV engine. Laters guys.
Old Dec 22, 2003
acidbaby's Avatar
The Beez Kneez
hit me up wit some results on the test man!!!!!!!!!!!!!! good job
Old Dec 22, 2003
Talking O2 sim test after install
Acidbaby, it worked out great! I just used some wire taps from RS and hooked up the four wires to my O2 sensor after the cat and bam! NO more CEL! Yay. ...And the people rejoiced! As did I. Laters dude
Old Dec 22, 2003
checking out my new sig---
Old Dec 23, 2003
Thumbs up my sig
Old Dec 23, 2003
acidbaby's Avatar
The Beez Kneez
cant c it
Old Dec 23, 2003
Dr5D's Avatar
I am sooo glad we dont have ANY car tests here in Iowa - we can do whatever we want!
Old Dec 23, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
damn in california, you could never pass a smog without a cat, they use mirrors to see if everything is their underneath the car, and also do a tailpipe test...
Old Dec 25, 2003
Angry O2 simulator problem
Alright guys I need help again. I have a Hi-flow cat and got a O2 sim. I hooked it up and no good. $5 min later the CEL came back on. I read again (the instructions) and it mentions every so lightly that the connections should start approx. 2 in from the O2 connecting plug. So, I redid the hook-up. The light came on after a 2 1/2 hour trip. So, I need to know am I doing more wrong. I notice when my Venom module is on too it used to come on faster. Are wire taps as bad as I heard for connections? Please give me some feed back. Thanks-
By the way you all feel like everytime you do something its just- in your face? Just me I quess.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
