odometer!
Old Oct 23, 2003
wogz's Avatar
wogz is an unknown quantity at this point
odometer!
how does a odometer work? and will changing wheel size effect just the speedometer or the odometer as well?
Old Oct 23, 2003
Voiceofid's Avatar
End Bringer
yes, chaning wheel size will affect the accuracy of your speedo and odometer
gauges works in a couple ways, a spinning reluctor, where a sensor counts how many times has the reluctor spin within a certain amount of time
spinning rotor, where the spinning rotor creates a voltage and the voltage becomes a signal for the ecm to determine the velocity, or rpm
marked rotor, simular to a reluctor, except this one has an eye that looks for one groove on the rotor itself.
there are some other ones, older cars also uses a different system, i don't know them yet
Old Oct 23, 2003
hassoomi's Avatar
go to the "Tire Calculator" on the left-hand menu to find out how much your speedometer will be off....
on another note, MAN, voiceofid, i've seen your avatar a million times, but i JUST noticed that the guy blinks. freaky......ummmm, yeah
Old Oct 23, 2003
Voiceofid's Avatar
End Bringer
it doesn't blink... you are just tweaking out
Old Oct 23, 2003
wogz's Avatar
someone told me that tire size effects the speedomter, but now the odometer! can someone tellme the truth? that knows for a fact what the answer is? thanks!
Old Oct 23, 2003
Voiceofid's Avatar
End Bringer
the odometer is effected, because it calculated accordingto your speedo, rpm isn't affected though
Old Oct 24, 2003
Logan3024's Avatar
I see it blinking.....are YOU tweaking?
Old Oct 24, 2003
robbclark1's Avatar
Retired suspension supermod.
It will change both....end of story.
Old Oct 24, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Robb is correct.
Wogz - you sure are an impatient n00b.
Old Oct 24, 2003
wogz's Avatar
i'm not a noob!
Old Oct 24, 2003
Zaskar2k1's Avatar
Zaskar2k1 is an unknown quantity at this point
Originally posted by VTEC01EX
Robb is correct.
Isnt it nice when we can say that now
Old Oct 24, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
if you get bigger rims, just get the right profile tires so that the overall diameter of the wheel is the same, and therefore you'll still get the same mileage as stock.
hondacivic0253
Sep 29, 2015 08:06 AM
Donahue
Sep 9, 2015 05:55 PM
msaeger
Sep 2, 2015 08:47 AM
NoobyKid
Jul 18, 2015 02:01 PM
