Header install help....
Old Sep 16, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
ok.. so far, i've read different stories on installing the header, now i have an EX first of all. i got all the other bolts off from the head, but from which side do i unscrew the bottom end. Do i unscrew the nuts on the header side, or do i unscrew the screws from the underside first... please help..
Old Sep 16, 2003
Da1lyDr1ver's Avatar
you have to go under the car and undo the two spring bolts holding the stock manifold together. when you're done, put the new header on and bolt it to the head. then put back on the two spring bolts that you took off from under the car. make sure you push the down pipe up when you're tighening the spring bolts or else the fit wont be tight.
Old Sep 16, 2003
CapYoda's Avatar
Escaped Convict
also.. the spring bolts are 16 lbs.ft only... dont overtorque. its easy to snap it.
same goes for the top nuts... they're easy to overtorque.. 23-27 lbs I believe, search the fourm, I've posted the specs before.
besides pushing the downpipe up as you tighten the spring bolts, alternate your tightening.. from left bolt to the right bolt.. so it'll fit firmly... its important cuz its easy to have that part leaking out exhaust.
and er.. I'm sure you're doing this when the car is cool... dont want to burn urself.
Old Sep 16, 2003
DogstyleEX's Avatar
lol.. thanks for the replies guys... so now i'm running into another prob.. the kamikazi header i bought from bigjoshracing didn't come with bolts... so i have nothing to screw the spring bolts to... what should i do? i think i might have to go down to home depot with the bolts and find some nuts that fit them...
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
