What is the voltage range of..
Old Jul 26, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question What is the voltage range of..
I was thinking of starting a project but I need to find something out first. The Temp and Fual guages in the cluster...I hear that they are reading voltages. So my question is, anyone know what voltage range they have? Is it like 0 - 12V or is it 0 - 8V. Anyone know?
Any help would be helpful. Even if someone could tell me where to get that info.
Old Jul 26, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
they don't read voltage. they read the resistance from the sender.
Old Jul 26, 2003
wonderz's Avatar
wonderz is on a distinguished road
if you really want the voltage for it...its like around 0.8V - 1.1V....I asked around for why that happened, but no one seems to know. I tested the voltage at the wire where it connects to the bulb. For some reason when i put in a 11.7V wire to the bulb, nothing happened (bulb didn't light up), but then with a 12V wire (from battery) the bulb lighted, but noticeably dimmer than when it got the 1.1V...
Old Jul 26, 2003
Sivion's Avatar
Resident Tough Guy
Exclamation So..
So they read resitance NOT voltag huh? Ok, so what resistance range is it then? I have no idea without some technical documentation...Was hoping someone would have the specific info.
Old Jul 26, 2003
wonderz's Avatar
any reason why they read resistance instead of voltage? hm..i'll check on the resist later
Old Jul 26, 2003
The fuel tank sender has a float inside the tank. As it moves according to fuel level, it moves a rod that varies a resistance of 11 ohms (full) to 130 ohms (empty). The wires are located in the fuel tank access under the rear seat. One wire is the ground, pin 1, black wire. Thus the gauge is measure a resistance to ground. The gauge sender wire is pin 2, yellow/black.
The electric coolant temperature sender connects directly to the ecu, then to the gauge, so there is not a direct connection that is recommended.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Hutch1051
Sep 29, 2015 09:20 AM
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:23 PM
