VTEC engagement
Old Jun 24, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
VTEC engagement
This issue STILL hasnt been clarified. Has anyone called Honda? My VTEC light was installed properly, and Seems that VTEC engages at 2,xxx RPMS.. somewhere around 2 to 3k.. that doesnt sound right cause I know VAFC LOWERS your vtec engagement... which would assume that its high in the first place to begin with... Anyone know? Why does my light come on early? And yes its wire 100% correctly.
Old Jun 24, 2003
blue03civic's Avatar
Pro Skater
i think it engages around 4,xxx rpms or so?
Old Jun 24, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
We don't actually know... The light gives you when the signal comes out of the computer, but that may or may not be when the high cam actually engages. There's 2 parts, theres VTC and then VTEC. They work as part of the same system to squeeze a little more kick out of the car. VTC (Variable Timing Control) advances the timing and then VTEC (Variable Timing and lift Electronic Control) is the part that kicks the extra set of cam lobes in. So what the light could be reading is the signal to advance the timing, then the cam lobes engage later when the solenoid locks them in. You may be getting the 1st part of a 2 stage process to engage VTEC. Sport Compact Car however reports that the Si (K20A3) does in fact engage VTEC at 2300... which explains why Apexi says not to install a VAFC on the car, and a VAFC 2 is coming... probably also explains the problems with our cars, and why they say the VAFC2 will work better on ours too... I know there are fixes for V1, but lets wait and see if it gets sorted out. Honda re-did VTEC for i-VTEC. It isn't exactly the same as what it was and its gonna take a little time to get all the little differences hammered out.
Old Jun 25, 2003
MangoEX's Avatar
Just Be
I just wanna know when the Cam profile shifts over :-) Thanks for the info boilmaker, I was kinda thinking the same thing.. maybe the light coming on is just a signal from the computer to prepare the oil sending unit to the VTEC line... who knows?
Old Jun 25, 2003
JLODVO's Avatar
JLODVO is an unknown quantity at this point
we have 2 vtec engagement coz we have 2 vtec seloniod, first 1 at 2+ and the 2nd at around 4-5+
Old Jun 27, 2003
aznrj's Avatar
aznrj is an unknown quantity at this point
i just got a V-AFC, what do you guys recommend, install it or sell it??
Old Jun 27, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
install it damnit. it works fine. GRRRR.
Old Jun 27, 2003
aznrj's Avatar
do you have it on your civic? and cons? problems so far??how long it take to DIY anyway??
Old Jun 27, 2003
RoBBUsaF's Avatar
check the other posts.. im posting a video later today. all pros
Old Jun 27, 2003
RoBBUsaF's Avatar
http://www.7thgencivic.com/forums/sh...02#post1178102
danace99
Oct 17, 2015 02:51 PM
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
beanhead
Sep 24, 2015 12:04 PM
