Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
Check Engine Light
Old Aug 2, 2006
SI mad's Avatar
SI mad is an unknown quantity at this point
Check Engine Light
I have a '99 Honda Civic Si, and I recently put on new Comtech header, Catback Exhaust, and a cheap EBay high flow catalytic converter (off road use only). In a 100 miles, my check engine light came on, possibly indicating that my emissions are off according to my owner's manual. Could the signal from the new catalytic converter be doing this or is something else wrong?
Any advice or info would be much appreciated. Thanks.
Old Aug 2, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
take it to a parts house and they should be able to runa diagnostic for free.... i know auto zone does that... but 100 miles after a "high flow cat" install from ebay sounds about right... that's probably all it is...
Old Aug 3, 2006
vtechsi's Avatar
vtechsi is an unknown quantity at this point
does the cat take the o2sensor???????? if the sensor was not installed then that is why your check engine light is on.....
Old Aug 3, 2006
05blkrs's Avatar
any half descent muffler shop would re-install an o2 sensor... it doesn't go in the cat either.. well, it may be built like that on some cars but you have one pre-cat and one post-cat... it doesn't have to go IN the cat
Old Aug 3, 2006
vtechsi's Avatar
on an 99-00 si they are part of the cat ... there are not a lot of companys that make a free flowing cat for a 99-00 si because of that reason
Old Aug 6, 2006
SI mad's Avatar
I had diagnostics done on my car and it came back as low back pressure in the catalytic converter. Is there any risk to my engine w/ this, or is it just because the oxygen sensors are set to a factory setting for the old cat?
Old Sep 19, 2006
mmacfady's Avatar
mmacfady is an unknown quantity at this point
I have a 2000 SiR adn the same thing happened. Mine came on after installing a new cat. The dealership said it shouldn't cause me any grief but the car might start running a little rough. I have had the cat and the light on now for over a year with no problems.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
