Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Door not locking correctly
Old Apr 20, 2010
TheGreen's Avatar
TheGreen is an unknown quantity at this point
Hi guys,
I did search and didn't find anything concerning this problem so I'm sorry if it's been posted. I just got a 04 civic coupe, which is the most basic model, with no keyless entry, and when I lock my door using the power lock inside the car, then I get out and close the door, if I try to open it again, it opens about 1 inch then gets stopped by the lock. This is pretty annoying since I bet it would make it a lot easier to steal. Also I have a hard time taking out my key from the lock when I unlock it. While shopping for my car, I've also seen another civic (03,04 or 05 cant remember), with the exact same problem, so I guess it's common.
Is there an easy way to fix this or should I just get the lock replaced (or do it myself).
Old Apr 20, 2010
lowlife9's Avatar
Re: Door not locking correctly
i had a similar problem when i took my door panel off i just sprayed some white lithium grease into the lock and moved the key back and fourth and repeated also on the part that contacts the door sill. also you can adjust either the metal hook on the door sill or the other part that contacts it i cant remember.
Old Apr 21, 2010
CraigW's Avatar
Are you aware that a Honda drivers door will not lock when it is open ??
The door has to be closed to lock properly.
You might try some lock graphite powder to see if it helps with the lock cylinders operation.
Old Apr 22, 2010
TheGreen's Avatar
Oh really? Well that's weird why the hell would there be a power lock then.. but it does lock correctly when I lock it with the key, but I have to wiggle it to get it out, I'll try to put some grease in there to see if it helps
Old Apr 22, 2010
CraigW's Avatar
It has been that way on the Honda models for quite a few years now. To prevent locking yourself out.
Old Apr 22, 2010
TheGreen's Avatar
well it's a good idea, except it does lock, just not completely, if I locked my keys in, I would still not be able to open the door...
Old Apr 23, 2010
CraigW's Avatar
You can hold up the outside handle or pull the inside handle out before locking when open and it will lock.
Each time I did this on my 05 it got all weird (lock **** stuck down and other scary things) so I quit doing it.
Old Apr 23, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
I've had to do this every time I get out of my car for the past 9 months on my 02..... (damn Dollar Store quality door lock actuators) and nothing scary or weird has happened...
BootyDo
Jun 21, 2016 03:45 PM
Jul 12, 2015 11:54 AM
General 7th Gen
Jul 9, 2015 10:17 PM
jferristx
Jul 8, 2015 10:09 PM
Spanky4269
Jul 5, 2015 09:40 PM
