Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Genuine Honda oil or not
Old Jun 10, 2008
Dantevil's Avatar
Dantevil is an unknown quantity at this point
I was just wondering if it's absolutely necessary that i use genuine honda transmission fluid in my car or can a substitute be used if it says that it can use in Honda. This is the first time i'm changing the fluid n i dnt understand the necessity of the genuine one.
Old Jun 10, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Genuine Honda oil or not
Most people fall on two sides. Some will say YES you need honda oil because of their additives. Others will say NO. I stick with genuine stuff.
Old Jun 10, 2008
TRIZ's Avatar
Stick with the honda transmission fluid- its one of the few fluids honda recommends you should use their "honda genuine fluid" that you should actually listen to.
Old Jun 10, 2008
CraigW's Avatar
OE Honda
What's your mileage at ??
I change at 25k miles.
Old Jun 11, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
I work at Honda and they use Castol. Kinda weird. (for motor oil)
Old Jun 11, 2008
CraigW's Avatar
Our dealer used to have Castrol & then switched to ?? They allow me to bring my own oil for changes now. I have used Castrol brand motor oil for a lot of years now.
Old Jun 11, 2008
honda atf only!! or you will have hard shifting and premature wearing of parts.
Old Jun 11, 2008
robbclark1's Avatar
Who said it was an automatic?
Old Jun 17, 2008
Dantevil's Avatar
yes it is automatic but genuine Honda fluid is hard to come by. I was told u get many gear issues with any other fluid but i would like a good alternative. have anyone gotten problems while using Catrol
Old Jun 19, 2008
cause we all know only cool people drive autos
Old Jun 20, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Getting the wrong fluid will mess up your tranny for sure.
I'm sure there are alternatives to getting the Honda stuff, but I guess it's kind of silly to risk it.
If you don't get Honda fluid you'll have to make darn sure, double and triple check it's the right stuff.
Old Jun 20, 2008
as far as i know, theres nothing similar you can buy.
Old Aug 7, 2008
ugabuga's Avatar
ugabuga is an unknown quantity at this point
Unless you are talking about automatic transmission oil, that's way too often.
I dont know about automatic but for manual i only use Honda oil and change it every 60k
Originally Posted by CraigW
OE Honda
Old Aug 7, 2008
yeah we were talking auto.
Old Aug 11, 2008
manahoonie's Avatar
it sounds like Dantevil is asking about ATF (AUTOMATIC TRANSMISSION FLUID)
half the posts i see in here are talking about MOTOR OIL...
and YES, I would stick with Honda ATF fluid when replacing that...Jiffylube first offered to change my ATF, but then one of their other employees said NO, because Honda has their own special blend that is needed...
Old Aug 15, 2008
eviee1973's Avatar
eviee1973 is an unknown quantity at this point
Honda uses a propriety blend of automatic trans fluid, Z1. I tried to use a non honda manual trans fluid (straight 30) I think, made it too difficult to shift, might be ok in warm climates. Trans fluid is inexpensive so why skimp out for the cost, be sure to get the aluminum crush sealing washers, should be changed each time
Old Aug 17, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
That's funny, I work at Jiffylube.
Our MT vehicles require MTF from Honda, but apparently 10w-30 works as a substitute. I obviously put in Honda MTF in my tranny but I remember the viscosity being similar to 10w-30.
On the other hand, whenever an AT 7th generation Civic pops by for a transmission fluid service, we use Quaker State Multi-Vehicle ATF. We have a chart that shows all the acceptable alternatives to specific tranny fluids, and that is one of them.
But evidently, an alternative is never better than the original.
Old Aug 19, 2008
ouch, yeah in this case using anything but honda z1 in the autos will affect shift quality. wont be nearly as smooth as before.
usajags84
15
Aug 19, 2015 03:12 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Unleaded
Jun 26, 2007 09:25 PM
Bartkat
20
Feb 19, 2002 01:29 PM
civiccowboy
Nov 19, 2001 03:44 PM
