question about headlights
just bought a used 2003 civic EX. the owner had "pressure washed it" and there is major moisture in the headlights. Have had the car for 5 months, and they have not dried out...any suggestions besides replacing the headlights? the headlights work great, I just don't like the look...someone suggested taking out the bulb and using a hairdryer....
Re: question about headlights
hmm weird, pressure wash should not get water in the lights as they are sealed around the edges with sealant. do you know how to take the headlights off the car? then you could seal them again from the outside with silicone. i know the stock goo stuff breaks down over time so maybe they just have holes where water can get in. for now, take out the rubber boot in the back where the bulb is and leave it open til the moisture goes away, prolly one day is enough. or faster would be a hairdryer inside but leaving open should work.
^drilling holes would work too to keep moisture from coming back again
just reach in back of the headlight, and you will feel the rubber cover and the plug. the plug will pull out, and then the rubber cover will too. you can leave the bulb clamped inside. just removing the boot will leave enough open air to let the water evaporate.
heres the rear of the headlamp. the arrows are pointing to the adjuster, and to the right of that is the rubber boot. the bulb would be inside there too but its not in this pic. just pull on those tabs sticking out.
civic98?
Aug 13, 2015 01:32 AM
knknif
Aug 4, 2015 06:11 PM
DerbyDad03
Jul 27, 2015 11:34 AM
NoobyKid
Jul 13, 2015 07:53 AM
