Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
SRS Light
Old May 22, 2006
Thunder Road's Avatar
Thunder Road is an unknown quantity at this point
SRS Light
The SRS light on my 97 civic came on by itself. Can pulling on the seat belt hard cause the light to come on. Is there a way to reset without going to the dealer
Thanks?
Old May 22, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
Is it constantly staying on now, or only coming on sometimes?
Old May 22, 2006
Is stays on all the time. Is it possible to pull on the seat belt to hard and set the light off?
Old May 23, 2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
You could unscrew the bulb in the light. (inside the electrcial panel or the fuse)
Or you could just disregard it as a fallacious warning light.
Will stress on the seat belts trigger airbags?
Old May 23, 2006
97_hatch's Avatar
97_hatch is an unknown quantity at this point
I'm not sure but I read somewhere on H-T you can relay that light using a pin. but youd have to go there for the diy..
My check engine lights been on for about 6 months now.. lol.. I dont even know it's there anymore..
But if you really do care for your saftey or something.. maybe it's telling you something is wrong with your airbag setup.. just a thought....
Old Jun 22, 2006
dapasda's Avatar
dapasda is an unknown quantity at this point
Smile SRS Reset
The SRS light on my 98 CR-V came on. I found instructions for resetting it at the following link:
http://www.geocities.com/myintegra96/srs.html
I followed the instructions, and it work perfectly. I printed out the instructions for future use. When you go to this link, you will notice these instructions are good for several vehicles, including 97 Civic.
I used speaker wire as a jumper. That way you can use a piece long enough to hook up and also view the dash while resetting.
Old Jun 25, 2006
Spoon97EK9's Avatar
Spoon97EK9 is an unknown quantity at this point
I would try to unhook the battery for a half hour to see if it goes off otherwise you can take out the gauge cluster and take out the bulb...
Old Jul 14, 2006
Willy2001's Avatar
Willy2001 is an unknown quantity at this point
As long as your belts are working and you're not married to your probably faulty air bag(s), then leave it alone.
However the SRS could be an early sign that your alternator is going.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
