Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Engine Light Stays On.
Old Aug 2, 2004
don's Avatar
don
don has a little shameless behaviour in the past
I Have a 2000 Civic Si and the engine light stays on. Yes, I have an after market superflow Cat. It is made for my car by Jackson Racing. I checked the computer with my Actron OBDII AutoCanner and it reads that the Cat is below threshold. But , the car passed the emmisions test. That does not make sense to me. I think it is electronic, because the car has great performance. Knock on wood! Maybe a wire is loose or broke. But that is just my opinion.
I would appreciate if someone out there who has a better understanding of this situation, would help me figure this thing out.
Thanks
D Rensi
Old Aug 3, 2004
k20importtuner's Avatar
k20importtuner is an unknown quantity at this point
It passed emissions because it's still a catalytic converter, if it was a "superflow test pipe" it wouldn't pass. I'm not sure why you're throwing a CEL, though. I'm more of an ep3 man than Ek, lol sorry
But it doesn't sound like it would be from your cat
Old Aug 3, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
How many miles are on the car? Is it the light that stays on because you need routine work done to the car? (Like a reminder built in) Or is it a REAL CEL? If it's a real CEL...I dunno man.
Old Aug 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
unhook the negative battery cable wait like 10-15 seconds and put it back on
Old Aug 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
otherwise if ur dealer is cool like mine they will run the check in the parking lot and print out what the code means and possible fixes for you
Old Aug 3, 2004
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
Would that work for a maintenance required light also?
Old Aug 3, 2004
No just CEL, I remember that trick.
For the Ep to turn off maintenance req'd you hold the key in the second position w/o turning the engine on and hold the milage button it.
It may work for whatever car you have but I'm not sure.
Old Aug 4, 2004
JX6's Avatar
JX6
didn't work on my 2001 civic ex
Old Aug 4, 2004
oh alright, nvm then. Must be just for us
Old Aug 7, 2004
03CivicEX_Kcrow's Avatar
03CivicEX_Kcrow is an unknown quantity at this point
To turn off the maint. req. light all you do is:
1. Take your left hand and stick it through the steering wheel
2. Push and hold the mileage rest button on the speedo gauge
3. While still holding take your right hand and put the key in the ignition and turn in to II
4. Hold it for a couple seconds and then the light should go off
If it doesn't work you are doing it wrong...the dealer showed me this and it works on any 7th gen I've done it to 3 other 7th gens
Old Aug 7, 2004
yeah, that's it, heh. But keep in mind he has an Ek, not a 7 gen. Idk if it's a new thing or not, oh well GL.
Old Aug 8, 2004
oh yeah...**** I overlooked that (him having an EK) when reading it...my bad
Old Aug 8, 2004
JX6's Avatar
JX6
Thanks so much!
It worked!
I'm thinking or removing my cat.We don't have emissions in Louisiana.So if I disconnect the negative it will cut the engine light off?
Sorry I don't mean to steal anyones thread.
Old Aug 8, 2004
Yeah i had a friend that did that and it worked. C2i0v0i1C said it works too (the whole disconnect the negative battery cable thing to reset your check engine light).
Old Aug 8, 2004
JX6's Avatar
JX6
I guess alot of people just don't know about it then.
I did searches and people are talking about o2 sensor simulators.
It would be cheaper just to do the battery.
I just wonder if the light would come back on.
I want to go gut my cat right now since I heard you get around 5hp.
Old Aug 8, 2004
JX6:
My friends check engine light came on because he was spraying carb cleaner in the throttle body to clean it out. I don't know why since he has an '04 with like 3000 miles on it. He was just being an idiot, anyways the light came on he disconnected the ground from the batt. and waited about 20 secs he told me and then he put it back on. He said the light went off I guess it reset the computer. But I figured if it threw a code it would still be in the computer so we hooked up my dad's OBDII code reader to it and it said everything was fine. I don't know if it will come on again or not he did this about 3 months ago and he hasn't said that it has come back on. It should come on if you gut the cat, right? If it does just do the batt. thing.
Old Aug 9, 2004
JX6's Avatar
JX6
I see.Well i'm not going to gut the cat.I'm going to keep it and get a test pipe from
www.meganracing.com
It has holes for o2 sensors and I am going to disconnect the battery before I install it.
Hopefully no lights will come on then.I really hope I don't go into Safe Mode aka "Limp Mode".I just wish i knew where the first o2 sensor is.
Old Aug 11, 2004
civicvtec1ps's Avatar
Search and Learn
If you buy Testpipe or eliminate cat, CEL will come off no matter what.
Couple options to fix the problem.
- You could get O2 simulator, which cost about $75-80. Plug in application.
Good and Bad reviews.
- Get Hondata Kpro and elminate CEL.
I am currently running Race header(no cat), and CEL light is on.
Doesn't do anything performance wise.
When you disconnect battery or reset ECU.
CEL will be gone for 50 miles then will come on again eventully.
You can reset ECU by taking out ECU fuse under the hood.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
