Question about oil changing interval
Hello all members ,
i have a question confusing me a lot , if i used " Mobil 1 5W-30 Extended Performance Full Synthetic Motor Oil " for honda civic 2000 can i change the oil after 15000 miles ??????
Best Regards
Best Regards
Re: Question about oil changing interval
after 15000 miles
Just because the bottle might suggest you can, does not necessarily mean you should.
Just my opinion but my first new car was a 69 Firebird Convertible. Kept it for 25+ years. Changed the oil every 4 months. Had .005 wear in the top of the cylinders at around 100K. (went into it because of frozen lifters) Went into my 85 Civic at 100K because of a broken camshaft. Cylinders didn't even have a top ridge and looked like new. Changed the oil ever 10 months or so as I recall. Averaged around 7-8K on the oil. My last two news ones 05 CRV and 04 Tacoma, I change every year. CRV gets about 10K on the oil. Truck only has 50K on it, so it's lucky to get 4K on it. CRV still runs like new at 90K I change the Civic when it tells me too on that maintenance monitor because it drive the grandson crazy. It and the CRV get free oil and state inspections for life. I seriously doubt once a year and or 10 K will hurt them. I been testing them since 1964 but I do live in a fairly warm area and drive them easy.. Just changed the bike and truck. Truck's filter is a royal messy pain.
I work at a Mobil 1, It's perfect with very little burn up to 10,000km or 6213 miles.
Mobil 1 extended performance is rated to 20,000km or 12,427 miles.
The thing is both of those are the max mileage for new cars. I've seen new toyota hybrids run 15,000km on Mobil 1 and the oil still looks mint, but our older cars would cook that oil of the stick if we ran them that long. If you beat on your car you will most likely want to swap early. As well most oil filters are full at 8,000 - 10000 km.
I guess you could swap your filter twice.
You go by level. Not amount. However you need to buy enough to do that plus an extra quart to have just in case you need to top off between changes. Read your owners manual on how to check transmission. Honda's are different then most automatics. Be sure to only use Honda's transmission fluid in the transmission. Use there power steering fluid also. No substitutes on theses two. You need about 3 quarts for transmission. 4.5 for the engine. (get 4 and 6..but use the dip sticks) The amount are in the back of the owner's manual under technical. You can download a copy from the Honda site if you do not have a hard copy.
and Auto trans will usually hold roughly 2.5 quarts for a single drain-and-fill.
When you check automatic trans fluid on any (real) Honda, the engine is supposed to be OFF.
As in shut the engine off and jump out and check trans fluid within 90 seconds.
I do my work on a hoist, car is fairly level during service..
If you have the front of your car jacked up in the air to drain fluids, this might change the amounts needed to refill by a bit.
HTH
just because an oil "looks clean", that doesn't mean its in great shape,
it doesn't matter how good of quality the oil is to begin with, it will still get contaminated by piston ring "blow by" and moisture just as much as any other oil would,
i am a believer of frequency over quality, as long as the oil is approved,
mattdoc
Mar 14, 2017 12:10 PM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
Grazzhopper
Nov 11, 2001 08:06 AM
