'05 DX Timing Belt relacement question?
Old Jul 23, 2010
paneldi's Avatar
paneldi is an unknown quantity at this point
What do I do?
I had to rotate the crankshaft pulley 2 rotations after the belt was off I know that your not supposed to do it. I used the replacement belt to turn the Crankshaft pulley and it was stubborn at first. The first go around it wouldn't come to rest at TDC the second time around the pulley was able to be moved to "rest" at TDC (it was late and a long day,-trying to do it myself)... The Camshaft pulley didn't move the entire time i was spinning the crankshaft.
What can I do before I put this thing back together only to find I've killed the engine. -Frustrated
Old Jul 23, 2010
Mad Dog Tannen's Avatar
Re: '05 DX Timing Belt relacement question?
I don't know if your engine is similar but this thread might help...
https://www.civicforums.com/forums/1...belt-boom.html
Old Jul 23, 2010
paneldi's Avatar
'05 DX Timing Belt relacement question, revisited...
The acid test...
First off, I must be an idiot, to save $ i have blown an entire night and am now working most of the morning in the rain to get the GF's car back together. Can I go back to work now please?$?
Here's what I've done, took the upper and lower belt covers off and backed out the spark plugs, turned the camshaft pulley 6-7 times noticing the "firing" of the cylinders and re-checked to see if the TDC marks were still GOOD and TDC. That all checked out so now I'm putting on the replacement a/c alternator belt and P/S belt then tightening everything in and praying I don't have any timing belt related problems for a long long time...
mattdoc
Mar 14, 2017 12:10 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
