coughing/sputtering idle - 95 Civic EX 1.6 VTEC
Old Apr 8, 2010
finkenator9's Avatar
finkenator9 is an unknown quantity at this point
I replaced air filter, spark plugs, and PCV valve, and changed oil and used synthetic oil.
I have a small idle problem. It sputters between 500-900 rpm at idle. It is intermittent, but definitely a small problem.
What should I check next? Is this something I need to take in and have the professionals look at it.
Other than at idle, the car runs as it should.
Service engine light is NOT on.
Car does not stall.
Old Apr 8, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: vacuum leak? 95 Civic EX 1.6 VTEC
the idle air control valve? you should diagnose the problem before spamming money at it.
Old Apr 8, 2010
laack's Avatar
laack is an unknown quantity at this point
+1 iacv. clean it + clean throttle body. before cleaning it, a quick test: warm up engine then disconnect the 2p connector on the iacv. rpm should drop to 450 and the CEL will come on since you disconnected it. if idle rpm doesnt change, you know its your iacv.
do an idle relearn after. your engine will still be warm and you need to clear the code you just caused. turn off car. disconnect battery for a couple minutes. reconnect. turn off all electricals (radio, heater, etc..) start car and let it run for 10 minutes. turn off car then go for a short drive.
fyi..suspect iacv only if it its surging after its warm. if i understand it right, iacv comes in to play after engine has warmed up. someone else correct me if i'm wrong.
If its not that, throttle air screw may need adjustment to help idle return to 750 rpm.
how has your mpg been? any other symptoms?
Old Apr 11, 2010
Ok, I cleaned my IACV, it wasn't real dirty, but the screen was a little clogged with dirt. I let it dry, then reinstalled.
Update:
Idle still coughing/sputtering at idle around 750 RPM.
Question:
Do I turn the idle screw clockwise or counterclockwise to increase idle speed?
Pr0n1s
Apr 30, 2015 03:08 PM
LionSpratt
Apr 26, 2015 01:02 PM
Tybonater
Apr 24, 2015 07:03 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
