What is wrong with my engine?
Old Mar 10, 2009
Tragedy's Avatar
skate or die
D17a2
1 O2 simulator connected to ECU.
Engine will not pass 4k RPM. I have to shift right before 4k RPM. If I try to keep going, the engine "quits" or "boggs down". Almost like it is giving up.
Is it the ECU, O2 sim, or internal problem?
The engine light comes on and off. When it is off i can go past 4k RPM.
This leads me to think the O2 sim is failing.
Opinions? Please...
Thank you,
Christopher
Old Mar 10, 2009
speedfoos's Avatar
Re: What is wrong with my engine?
It's the O2 simulator throwing your car into limp mode which is why you can't go over 4K on the tach. Remove it use a spark plug defouler to fool your ECU into thinking you have a cat.
Old Mar 10, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i think its a different problem. even with me running no o2 sim or defouler and the ecu knowing my car has no cat it still runs fine. when the CEL is flashing it usually means your engine is misfiring big time.
was it running fine before and this just happened randomly? or did you install it and its doing this now? if it just happened after the install it could be the o2 sim. check your vtec wiring first and maybe clean out your vtec solenoid screen. thats an easy way for the car to throw limp mode. same thing happened to my car and it ended up being my vtec screen.
Old Mar 11, 2009
Civic_JDM's Avatar
Civic_JDM is an unknown quantity at this point
It may not be the O2 coz when i have my civic i have no cat too....coz the ecu already know u r running without a cat so the CEL will be on...use obd and it will show u wht's wrong with ur car or the motor...
Old Mar 11, 2009
did you get a code when the light came on?
Old Mar 11, 2009
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Pull the code... There will probably be a stored code even when the CEL is off in your case so if you get the code you will know the issue.
Old Mar 13, 2009
Tragedy's Avatar
skate or die
I have not taken it in to check for a code.
Thanks for the input guys, the O2 sim was working fine for months before this randomly happened. Today the engine light went off and on again after an hour of driving.
Guess I have to check for a code and take it from there. 95,000 miles under her belt. ya-yuh.
Old Mar 13, 2009
drunkenmagnum's Avatar
Its a D17, theres your problem.....
but really it could be your VTEC sylenoid too. I had the same issue and thats what it turned out to be. A 02 sensor wont make your car go limp. I ran with my CEL on for months before putting a defoiler on it.
In fact your problem sounds exactly like my problem and at the same RPM.
Old Mar 16, 2009
Tragedy's Avatar
skate or die
good to know, it does sound like i might need to clean it up. Recently for the past 2 days, it has been running fine with no cut off.
so im scratching my head on this one.
mikemc422
Aug 9, 2018 05:41 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
BREADFAN
Apr 15, 2015 08:58 AM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
