Time To Change My Tranny Fuild And Antifreeze...
Old Sep 29, 2006
IrockCivics's Avatar
Its time to change my transmission fluid and anti-freeze. when I go to the local shop to buy this which name brand should I be looking for? and how many of these stuff do I need? I have a automatic just incase that helps. Thanks.
Old Sep 29, 2006
Kevbotron's Avatar
I like my commute
I went to my Honda dealership and picked up 3 quarts of Honda ATF, cost like 45 bucks for both the fluid and the service to have my car flushed and replaced had it done at 42K mi
Old Sep 29, 2006
oem only, buy from dealer
Old Oct 8, 2006
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
I asked for a quote from the dealer and they said $100 for all the fluid and labor for the tranny and coolant.
Old Oct 8, 2006
german import's Avatar
german import is an unknown quantity at this point
Motul Motylgear 10w40, you won't be disappointed. A little heavier than the oem stuff but if you have any grinds this stuff will make a difference. Give it a try! Designed for japanese transmissions!!! If you need some pm me and I can point you in the right direction.
Old Oct 8, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
cant use 10w40 in auto trannys though
Old Oct 8, 2006
I'm so very sorry, I totally overlooked the fact the this car is clearly stated to be an automatic!!! Thank you for the correction!! Again I'm sorry.
Old Oct 8, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
There are other coolants on the market that would work just fine. But the way i see it, why not just use honda's since it doesn't have to be changed often.
Old Oct 9, 2006
burke420's Avatar
The World Is Yours!
i went from Castrol....= crap! to Honda ATF....deff. a difference! better go with oem on tranny fluid!
Old Oct 11, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
100 for both transmission and coolant is very good deal...
fluid alone is way over $50
Old Oct 11, 2006
how many gallons of anti-freeze do I need from the honda dealer? and how many quartz of transmission oil will I need also?
Jigee
May 9, 2015 11:18 AM
lildoo
May 9, 2015 09:44 AM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Unleaded
Jun 26, 2007 09:25 PM
