different oil filters
Old Apr 13, 2006
bigsamdog's Avatar
k!llin al-queda since 2002
bigsamdog is an unknown quantity at this point
went to the store today cause im gonna change the oil myself and when i was gettin an oil filter i saw some that read PH5,PH8A and some other ones i cant remeber, is there a specific one for our civics? oh and i have an 03 ex 5spd if it matters
Old Apr 13, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Fram P/n PH7317.
IBTL
Old Apr 13, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
LOL
IBTL X2
Old Apr 13, 2006
DDragon7's Avatar
IBTL X3
Old Apr 13, 2006
R1Style's Avatar
Different filters have different part numbers. Ask the person behind the counter which one is for your civic.
Old Apr 14, 2006
Jrfish007's Avatar
There should be a book by the filter saying which filter is right for your car.
Old Apr 14, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
it's odd....the older civics take the standard 3593....7317 started with our car....and is now on the element, and some of the other cars....of course the v-6's still take the 3593....
oh and IBTL X 4
Old Apr 14, 2006
Jrfish007's Avatar
oh and IBTL X 4
A few years ago Honda got the idea of cutting costs by only having to carry 2 filters in their dealerships and only having to have produce 2 filters, rather smart idea IMO. Hence they are trying to get all Hondas on to one filter. I was actually told at Honda the other day that even the older civic are using the same filters as the new ones at Honda. I'm guessing the Fram books have not been updated. But basically everything with 4 cylinders gets one filter (except the S2000), and everything with 6 get a different one.
Old Apr 15, 2006
shroomster's Avatar
the 5-cylinder vigor (acura) had some weird *** random size filter...dunno what that was about...
Old Apr 15, 2006
Yeah, the NSX's and the Legends also use a PH8212. One time I sent a tech inside to get one and he said we didn't have one. Then I went in there about two hours later and turned out we did carry it, but we didn't even know about it. Stupid companies making unnecessary filter changes...
Old Apr 15, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
*** FRAM keep it OEM or Hamp
Old Apr 15, 2006
02BLKCIVIC's Avatar
on that subject:^^^^^^^^^^^
NSX Prime Sight
Fram
[RWI] I used Fram once with disasterous results. About 4 years ago, I decided to change my oil one Sunday. Unfortunately, no Acura dealers were opened on Sunday. So, I ran to my local Pep Boys and puchased myself an equivalent Fram filter. Did my oil and filter change as usual and went for a test drive. After about 20 mins driving around, I decided to take it to about 100 mph. Guess what, my oil presure dropped to zero and one of the idiot lights started blinking.
I immediately shut the engine off and assesed what had happen. There was smoke coming from the rear right side of the car but not on the left. Believe me, it was a scary experience. I was almost in tears while I pulled off the side of the road. I got out of the car and saw a trail of oil on the road leading up to my car. I remember praying as I carefully peeped under the car. First thing I noticed was the car's left underside was very clean. I decided to jack up the car right there and then so I could see more underneath. Further examination revealed the Fram rubber seal burst spilling most of the oil out of my engine.
I told myself then, I will never ever use a non-factory filter my my NSX again.
The next day, I took my car to the dealer and had them checked everything in my engine. Fortunately, the dealer said the engine has no detectable damage. It took at least 3 under carriage steam cleaning before I got all the oil out of the little crevices under the car. The moral of the story, don't skimp on oil filters, use the oil filter specifically designed for you car.
[DNG] Fram oil filters are know for this. Frams were banned from being used on race bikes since they kept blowing. I'd rather spend $4 more for piece of mind with the OEMs.
Old Apr 16, 2006
Super Member
exactly.. keep it OEM.. you wouldnt want that happening now would you.. or maybe you do then you can collect a check from FRAM
Old Apr 16, 2006
SilverVTEC's Avatar
SilverVTEC is an unknown quantity at this point
well that is indeed a horror story about fram, but i have used them in my Z cars, mustangs, and my civic with NO problems what so ever. so i would say they are fine. Im sure that has happened to someone out there with a OEM filter, sometimes products just fail! For example: Simpson makes some of the best safety equipment(seatbelts), well one fail and Dale Earnheart was killed, but other racers still use the seatbealts...get my point?
Old Apr 17, 2006
Jrfish007's Avatar
Never mentioned Acura, they figure if you have the money for an Acura, you have the extra couple of bucks for specialized filter I guess.
mistermenphis22
Jul 13, 2015 04:43 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
