Halo Projector Installation
Old Oct 5, 2012
blaqkciv's Avatar
blaqkciv is an unknown quantity at this point
Hello all, I was wondering if anybody has happened to install a pair of projectors which require the wiring of the separate LED wires. If so, I was also wondering what gauge wires to use when splicing the LED wires into wire harness of my car with the quick connect. Do the wires being spliced into the harness need to be automotive specific? Or will any do just fine without melting. Any information will help! Thanks!
Old Oct 6, 2012
Re: Halo Projector Installation
LED is low power and can be tapped to anything. most people just use the park light wires so you dont have to run the wiring inside the car. just tap to + and - of the park light on each side. the led halo is less than 1w of power and will not require anything other than tap them to a power and ground. if they dont work, reverse the polarity and try again.
Old Nov 26, 2016
ShattaD EM2's Avatar
ShattaD EM2 is an unknown quantity at this point
I've got a 2005 ex special edition manual with the r8 helo projectors that come with led daytime running lights by Spec-D . I was looking for a constant power wire to hook them up to. And where would be a good place to ground it?
Old Nov 30, 2016
When I rocked my halos (before one of the inverters died), I straight up tapped my parking light wires and connected it using T-taps (both ground and +12VDC lines). Worked just fine.
Old Dec 24, 2019
Brads Si's Avatar
Brads Si is an unknown quantity at this point
I am trying to get a set of the same lights. So far, the right/passenger side, I have had issues with some of the LEDs burnt out on arrival. The 3rd lamp is supposed to arrive today.
Your post is from a few years ago, how have your lamps held up over time?
I am wondering if there is a place in the under hood fuse box to hook in for accessory power for the LED DRLs. I want them to off and on with the key.
Old Dec 24, 2019
That dude hasn't logged into the site in 2 years, but to give you an answer, lots of those 3rd party LED halos suck, to be completely honest.
As far as under-hood accessory power, I do not believe there is one that is on/off with the key. Your best bet is to route a wire into the cabin and fusetap the cabin fuse box. The ECU wiring has a grommet you can fish a wire through. It's on the passenger side, about halfway down. Not terribly hard to access, a lot easier if you have an aftermarket intake. I was able to fish a 2AWG wire through that grommet in my 2002.
Old Dec 24, 2019
Brads Si's Avatar
Thank you, I was wondering about that. Any idea what fuse would be best for tapping into under the steering wheel?
Old Dec 24, 2019
what year/trim you got?
Old Dec 24, 2019
Brads Si's Avatar
2005 Civic EX 2 door 5 speed
Old Dec 24, 2019
Fuse 3 or 12. Use a multimeter and see if you get voltage when you want it. Those are both slated for DRLs (3 says "DRL" 12 says "DRL Canada" )
otherwise, fuse 8 (acc radio) or 18 (cigaretter lighter adapter), might be viable choices
use one of these.
Lets you hardwire without splicing anything, and still provide fused power to the fuse slot's original target load. Just gotta find you a good ground point for the LED DRLs, and that can literally be any bare metal. Anywhere. Ground those LEDs out in the engine bay and grab power via fusetap from the cabin.
edit: source for fuse loads here: https://troubleshootmyvehicle.com/ho...-dash-fuse-box bc I don't own a 7thgen anymore
Old Dec 24, 2019
Brads Si's Avatar
THANK YOU SO MUCH!!!
Just installed the lights in the car. They look great. I'll order the fuse tap off of Amazon and hook up the LEDs when they arrive.
Old Dec 24, 2019
Heads up, first fusetap I bought was on amazon for like 7 bucks. Second fusetap I bought was from autozone for like $7.50. Currently using one to power my dashcam and another to power my footwell lighting
Got any more questions, feel free to post up, my dude.
edit: I've done my fair share of dicking around with headlights. I know a thing or two. See if @sdaidoji will post up his headlights, if he installed 'em/still has 'em. I made that retrofit with custom LED lighting on the inside.
edit 2: I forgot, I posted pics of them, too. Check out the "her baby blues" link in my signature. Those are wired up to be on only when the parking light is on, however. They weren't wired in as DRLs
Old Dec 25, 2019
woups, no, have been busy with a computer that does not boot...
When I was in Canada, we ended up wiring the halos as DRL, although my old Amzo headlights were really not that bright, but the module worked on them.
The inspection station was dark, so the halos looked bright. (I took my US Civic with me for 1 1/2 years in Quebec, so that was the required modification)
Old Jan 2, 2020
Brads Si's Avatar
I hooked up the DRL yesterday. For anyone reading this later on. Fuse 3 is on and off with the key. Fuse 12 is constant hot.
Thank you for the tip on running the wire in by the loom behind the air filter box. It is a nice clean install running through there.
use one of these.
Old May 7, 2020
Brads Si's Avatar
The LED DRLs on my wife's 2005 EX Special Edition are still looking great.
HOWEVER, on my 2013 Si, when I hit the unlock/lock, my DRLs come on, and stay on for a short period of time to illuminate the way into the house.
My wife is wondering if there is any circuit in the 2005 to allow her DRLs to do the same thing when she comes home at night.
Old Nov 23, 2022
gatrhumpy1's Avatar
gatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of light
So I just got new projector headlight assemblies for my 2004 Civic VP. They look amazing. The low beam is an H3 bulb assembly. I just bought two H3 LED bulbs to replace the low beam headlight bulbs. The question is, looking at a typical H3 halogen bulb, it seems like they light up forward facing. The H3 LED headlight bulbs I got do not have forward facing LEDs, but rather 24 individual LEDs in a pattern like below. Is that going to still light up properly in the new projector lights?
Old Nov 23, 2022
the question should be if the leds are same position as the halogen bulb filament
https://www.civicforums.com/forums/2...ype-bulbs.html
Old Nov 23, 2022
gatrhumpy1's Avatar
I got those same exact LEDs as above, and the H3 halogen bulb I have is in a projector lense, not a reflector lense.
Old Nov 23, 2022
honestly, you will need to test both against a wall to see if it works
i see what you mean
Old Nov 23, 2022
gatrhumpy1's Avatar
These are the stock H3 low beam bulbs that came with the new headlight assembly. Not bad. A little uneven, but not bad. Once I get the new bulb I will put one in and see the difference.
Old Nov 26, 2022
gatrhumpy1's Avatar
The light output on the new H3 LEDs sucked donkey *****!! Look at this garbage!! First picture below is the stock vs. LED output. Stock H3 bulb is on the left.
Old Nov 26, 2022
gatrhumpy1's Avatar
And the H3 LEDs had six forward facing LEDs as well!!
yingjai
Apr 26, 2008 03:05 PM
mikemal
Apr 18, 2006 07:57 AM
mikemal
Apr 14, 2006 12:05 AM
civicguy777
Aug 29, 2004 02:57 PM
hondacivic218
Mar 26, 2004 08:03 PM
