Installing the Optional Armrest
Old May 17, 2004
Forum Bot's Avatar
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Post Installing the Optional Armrest
<table><tbody><tr><td><font face="Verdana">All the included hardware. The armrest cost me about $60US at the dealership. They wanted $110 to install it, and I said forget that.<br />You will need a 10mm and 17mm socket, needle nose pliers and a sharp utility knife.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000074s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Start by reaching underneath the drivers seat and you will feel where the plastic clips are. Pull it toward you till it unhooks as shown in the picture.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000066s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Lift the back of the seat cover up to expose the insides. You will see a grey cover that needs to be removed by lifting it up over the black U-shaped bars.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000067s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Once the above is removed, you will see 2 clips attached to the same U-shaped bars. These need to be unhooked.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000068s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Once unhooked, you can push/pull the seat cover and hooks between the seat back and seat bottom.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000069s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Lift the front of the seat cover up and you will notice a spring attached to it. This needs to be removed from the rear and is quite easy.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000071s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Lift the side of the seat cover up to expose an indentation of where the armrest bracket will go. This needs to be cut out as shown below.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000072s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Use a sharp utility knife to cut the foam out.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000073s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Once this is done, pull the the seat cover back down so it is nice and tight, like it was before you started. This part is tricky. You will need to cut an X in the fabric enough so that the bracket will fit in so you can screw it in. Don't go too far with the cuts cause you don't want them to show once the armrest is on.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000077s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Slide the bracket in and line up the screw holes on the bracket with the screw holes on the seat side. Insert the screws and tighten. There is no wrong way to put the bracket on, as long as the thread end is pointing outward, which is fairly obvious.</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000078s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Unzip the armrest and peel down the outside of it. (The side pointing towards the passenger seat.) Make sure the other side is nice and tight. Slide the two white bushings onto each side of the armrest. Slide the armrest onto the bracket. While pushing the armrest onto the bracket, add the brass washer, then the lock washer then the bolt. Tighten the bolt. Test the armrest functionality. If all is fine, pull the cover over the armrest and zip it up. (Not as easy as it sounds. I used needle nose pliers to do it.)</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000080s.jpg" width="400" border="0" /></font></td></tr><tr><td><font face="Verdana">Another pic</font></td><td><font face="Verdana"><img height="300" alt="" src="/diyimages/Im000079s.jpg" width="400" border="0" /></font></td></tr></tbody></table>
Old May 1, 2011
kickme005's Avatar
kickme005 is an unknown quantity at this point
Re: Installing the Optional Armrest
is it possible to install a arm rest on the passenger seat?
Old May 2, 2011
no because its just cushion. there is no metal bracket to mount it.
Old May 6, 2011
lazlong's Avatar
Wow, resurrecting a 7 year old thread. Isn't that a record? lol
Old May 8, 2011
thesushiboy's Avatar
200,000 and counting
thesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the roughthesushiboy is a jewel in the rough
Very cool writeup. Looks like you can pick up the armrest at handa-accessories for about $42.
Old Nov 9, 2011
clams's Avatar
clams is an unknown quantity at this point
Thank you for the DIY, this post is awesome. I just installed this armrest!!!
Old Mar 30, 2013
ClaytonKimball's Avatar
ClaytonKimball is an unknown quantity at this point
I wasn't able to find a new armrest anywhere (all saying it's no longer available). But I found one at a Pick n Pull in great shape. Thanks for the instructions.
BootyDo
Jun 21, 2016 03:45 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
General 7th Gen
Jul 9, 2015 10:17 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
