Reading SRS Codes
Old May 27, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
Reading SRS Codes
Reading SRS Codes
Unfortunately, we don't all have access to OBD-II readers that also do SRS codes. Hopefully this will aid some people in the diagnosis and repair of their vehicles.
Symptom-based Troubleshooting
4-door
SRS indicator light does not come on
SRS indicator light stays on after the ignition switch is turned on (II)
(editing in progress)
5-door
DTC-based Troubleshooting
1. Make sure the ignition switch is OFF and wait for 10 seconds.
2. Bridge OBD-II connector pins 9 and 4 with a paperclip or a suitable short length of wire.
3. Turn the ignition switch ON (II). The SRS indicator light comes on for about 6 seconds and then goes off. Then it will indicate the DTC.
4. Read the DTC. There will be a set of slow flashes, followed by a set of fast flashes.
5. Turn the ignition switch OFF and wait for 10 seconds. Then remove your paperclip jumper (or wire) from the OBD-II connector.
DTC Code Lists:
NEC (M2), DENSO (M1) SRS unit (Without Side Airbag Model)
SIEMENS (M1), KEIHIN (M3) SRS unit (Without Side Airbag Model)
SIEMENS (M1), KEIHIN (M3 or M4) SRS unit (Side Airbag with OPDS Unit Model)
SIEMENS (M1 or M2), KEIHIN (M3) SRS unit (Side Airbag without OPDS Unit Model)
Old May 27, 2011
DTC Code List: NEC (M2), DENSO (M1) SRS unit (Without Side Airbag Model)
DTC Code List
DTC, Detection Item
1-1 Open in driver's airbag inflator
1-2 Increased resistance in driver's airbag inflator
1-3 Short to another wire or decreased resistance in driver's airbag inflator
1-4 Short to power in driver's airbag inflator
1-5 Short to ground in driver's airbag inflator
2-1 Open in front passenger's airbag inflator
2-2 Increased resistance in front passenger's airbag inflator
2-3 Short to another wire or decreased resistance in front passenger's airbag inflator
2-4 Short to power in front passenger's airbag inflator
2-5 Short to ground in front passenger's airbag inflator
3-1 Open in left side seat belt tensioner
3-2 Increased resistance in left side seat belt tensioner
3-3 Short to another wire or decreased resistance in left side seat belt tensioner
3-4 Short to power in left side seat belt tensioner
3-5 Short to ground in left side seat belt tensioner
4-1 Open in right side seat belt tensioner
4-2 Increased resistance in right side seat belt tensioner
4-3 Short to another wire or decreased resistance in left side seat belt tensioner
4-4 Short to power in left side seat belt tensioner
4-5 Short to ground in left side seat belt tensioner
5-1, 5-2, 5-3 (NEC), 5-4, 5-5 (NEC) Internal failure of SRS unit
6-1 (NEC), 6-2 (NEC), 6-3 (NEC), 6-4 Internal failure of SRS unit
7-1, 7-2, 7-3 Internal failure of SRS unit
8-1, 8-2, 8-3, 8-4, 8-5, 8-6 Internal failure of SRS unit
NOTE: Before troubleshooting DTCs 5-1 through 8-6, check battery/system voltage. If voltage is low, repair the charging system before troubleshooting the SRS system.
9-1 Internal failure of the SRS unit. If intermittent, could mean internal failure of the unit or a faulty indicator light circuit. Refer to Troubleshooting Intermittent Failures (see page 23-38).
9-2 Internal failure of the SRS unit. If intermittent, could mean internal failure of the power supply (VB line). Refer to Troubleshooting Intermittent Failures
9-6 Faulty left front sensor
9-7 Faulty right front sensor
10-1 Seat belt tensioners (and airbag(s)) deployed
Old May 27, 2011
DTC Code List: SIEMENS (M1), KEIHIN (M3) SRS unit (Without Side Airbag Model)
DTC Code List
DTC, Detection Item
1-1 Open or increased resistance in driver's airbag inflator
Old May 27, 2011
DTC Code List: SIEMENS (M1), KEIHIN (M3 or M4) SRS unit (Side Airbag with OPDS Unit M
DTC, Detection Item
Old May 27, 2011
DTC Code List: SIEMENS (M1 or M2), KEIHIN (M3) SRS unit (Side Airbag without OPDS Uni
DTC, Detection Item
Old May 27, 2011
MindBomber's Avatar
Live for the Twisties
Re: Reading SRS Codes
Excellent thread. I know there's something similar on the site already, but it's buried in the archives and I can't find it.
Old Jun 10, 2011
mcbakker100's Avatar
mcbakker100 is an unknown quantity at this point
Hi all,
I have a question.
I have codes 5-1 and 5-2. I bought a crashed civic and the drivers (steering wheel) and passangers airbags (dash) are out. So I assume i have to replace the both sensors in the front, the airbags and the srs unit.
Why i see only 5-1, 5-2? do i need to change the srs unit first to see the other codes?
Thanks. Greetz, Maarten
Old Dec 1, 2011
Shine.'s Avatar
Shine. is an unknown quantity at this point
I have no idea how to read my code..Can anyone here give it a shot?
http://www.youtube.com/watch?v=tlRmE...el_video_title
Old Dec 11, 2011
04 Honda Civic's Avatar
If I have the "side airbag off" light do I use this method or a different method?
Can I also use the 2 pin connector that is used to reset the code to read it as well? This is what the manual states I believe.
Lastly what would be the code for a bad OPDS?
Old Mar 16, 2015
tempid's Avatar
tempid is an unknown quantity at this point
Thanks everyone. I followed the steps outlined in this thread got a 9-3 which seems to be the seat buckle issue. I put the seat belt on/off into the buckle and the red symbol went on/off correctly with my actions. Also opened the buckled and blew compressed air into it. I've then erased the code and it airbag light hasn't come up so far.
Thanks again for all the help. I really appreciate it.
Burnout
Jul 15, 2022 10:24 PM
mapdog
Jun 22, 2015 05:36 AM
Blazz
May 25, 2015 10:56 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
tylerginevan
Apr 27, 2015 12:29 PM
