DIY: SRS Codes and reading them
Old Jul 16, 2009
Wolfgang5884's Avatar
While searching around on how to figure out why my SRS light was going on and off I found this site. Great information on how to manually read the SRS codes! So you don't have to give your money to the dealership!
Thanks to R3dline from ClubRSX.com
Everything is the same except our OBDII port is rotated 180 degrees and will look like this,
I tried to search to see if someone has already posted, so sorry if it's a repost.
ID:	76929   Click image for larger version
Old Jul 16, 2009
denice25's Avatar
Member
denice25 will become famous soon enough
Re: DIY: SRS Codes and reading them
thanks for the share...nice post!
Old Dec 1, 2009
mywifem's Avatar
mywifem is an unknown quantity at this point
Great post I am looking for. Thank you~~
Old Jun 29, 2010
virgil604's Avatar
virgil604 is an unknown quantity at this point
Thumbs up Re: DIY: SRS Codes and reading them
ty very good post it help for 2006 civic to find the codes.
Old Jul 19, 2010
HondaB18c1's Avatar
HondaB18c1 is an unknown quantity at this point
If you have a srs code and your airbag light is on. Go to this site Cartipsntricks.com , if u have a faulty airbag, and your light is on, this site explains how to fix your airbag issue with a resistor and also how to reset your SRS/Airbag light.
Old Jul 22, 2015
JD101's Avatar
JD101 is an unknown quantity at this point
Usually this driver side air bag light ON problem is due to driver side seat belt switch, My driver side seat belt buckle goes on and off as it should,( I can watch the light go on and off on the dash board), could there be another sensor inside the buckle which sends signal to the computer? Also is this connector pin configuration and orientation good for Honda Civic 2003? Can you get the DTC code by the OBD scanner?
Old Sep 2, 2015
mohalo's Avatar
mohalo is an unknown quantity at this point
You can hook up an OBD scanner to check if there is stored DTC. if yes, erase the DTC and follow scanner prompts
matman
Aug 7, 2019 06:15 AM
mikey1
Sep 20, 2018 11:13 PM
crazyone64
Sep 14, 2018 07:54 PM
Kennykenny
Dec 5, 2013 09:43 AM
threeoten
Jul 26, 2012 09:12 PM
