LED Headlights and DRL
Old Jan 5, 2020
mafiaboy01's Avatar
mafiaboy01 is an unknown quantity at this point
I recently installed some LED headlights on my 2001 Civic. Hi/Lo beam work great but they don't work when the DRL are on.
I know the Civic runs the highbeams in series for the DRL and I'm guessing the LEDs are so low resistance they don't light up properly.
Has anyone come up with a solution for this? Do I need LEDs that support operating at lower voltage or can I install some resistors to run the highbeams in series?
Old Jan 5, 2020
Colin42's Avatar
Re: LED Headlights and DRL
There's usually a separate module that you can buy to make the DRLs work. The bulbs I had for my 05 had the module already wired in (separate high and low bulbs). Or if you have fogs you can wire those to be your DRLs.
Old Jan 9, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
You will get flashed by oncomig vehicles as plug and play LED bulbs are not designed for halogen housings. The beam pattern will be scattered and you will have reduced visibility. Unless you have retro fitted a projector housing.
No DRL means no passing inspections at least in my neck of the woods.
Old Jan 9, 2020
mafiaboy01's Avatar
Ya the beam pattern ended up being garbage. Switched back to halogens for now. I'm going to do the projector retrofit instead and rewire to run the parking lights or fogs as DRL.
Old Jan 9, 2020
NDNV's Avatar
That's the proper way to retrofit LEDs should you have the time, patience and $. Good luck on the project and post photos of your finished headlights.
Old Oct 12, 2021
Old Faithful's Avatar
Old Faithful is an unknown quantity at this point
Sorry to revive an old thread, but are you saying you had High Beam LEDs that worked in DRL mode on your 7th gen Civic, that feeds the high beams in series in DRL Mode (effectively lighting the high beams at quarter intensity)? If so, what brand were they? I can't seem to find ANY LEDs that work properly, and I've been literally checking every compatible 9005 LED on amazon.ca for days on end...
Old Oct 12, 2021
Colin42's Avatar
I'll check my Amazon history
Old Oct 12, 2021
I used a Hamsar unit from Canadian tire back in 2010 when i had to move to Quebec. I did not have fog lights so i did wire my halos
Old Oct 12, 2021
anyone remember what the DRL voltage is? Is it half voltage or was it a straight 5?
I've been trying to find [reliable] LED 9005s (I think that's the high beam bulb, at least) with a minimum operating voltage of 5-6V, but only found one from VLEDs with an 8V minimum operating voltage
Old Oct 12, 2021
Colin42's Avatar
I think half voltage, the drl unit (in the older cars) was just basically a big resistor pack and a heat sink. It would probably work with 5v though
Old Jun 21, 2022
DavonCain's Avatar
DavonCain is an unknown quantity at this point
Probably the problem is in the connection of the sidelights. You need to reconnect the sidelights. The most reliable and easiest option is to connect the sidelights without a relay but with a special control unit for running lights. It ensures the switching of the sidelights after the engine is started, ensures safe operation, protects against overloads, and can be installed on cars with any type of lamp, including LED lamps. When I had the same problem, I also changed the lights in the car's interior: https://www.vont.com/product/vont-ca...t-strip-light/. If you use only high-quality LED bulbs, then there should be no problem! There are a lot of options! You need to try all ways!
Chris Ray
Lighting
Aug 19, 2019 06:58 PM
jonathan_oakley
Lighting
Jun 4, 2019 03:08 AM
narindersoi
Dec 1, 2017 08:54 AM
7thGenMarks
Sep 19, 2016 02:31 PM
Hoac
Lighting
Feb 23, 2011 02:23 AM
