DRL (High Beam Bulb) TO CONSTANT 12V
Hey all, as the title says, I want information about how to make the drl (High Beam Bulbs) to constant 12v instead of 6V. The reason is that I installed LED 9005 Bulbs in the High Beam Sockets but they only light up at 12v. So actually they arent working unless I put my high on.
Thank You
Note, I used the search function and Did not find anything.
Thank You
Re: DRL (High Beam Bulb) TO CONSTANT 12V
thats tricky to do because the drl module and wiring is all tied into the car harness. prolly would be easier to wire the led bulbs separately to a switched ignition power source and bypass the stock wiring.
alaga
25
Aug 13, 2015 04:42 PM
j-chest
Jul 31, 2015 01:18 PM
sch2cm
Jul 21, 2015 09:58 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
