RCP - H4(9003)- LED Headlights drl flickering
Old Jun 3, 2019
jonathan_oakley's Avatar
jonathan_oakley is an unknown quantity at this point
Installed these on my 2002 civic dx, they work fine when turned on, and on high beam but when i turn them off i noticed the daytime running lights flicker constantly (they never did that for about 2 weeks). Not a huge deal but is there a fix for this or is it just the way they work in these older cars? The led's came with the extra connection wire/unit that's supposed to provide the correct voltage that goes between the actual light and the harness on the car on each side.
Old Jun 3, 2019
Colin42's Avatar
Re: RCP - H4(9003)- LED Headlights drl flickering
Did you install that extra box?
May need to get a different canbus adapter
Old Jun 4, 2019
Slumpertcivic's Avatar
DRL works by linking the lights so that they only get 6volts each. If it worked for few weeks fine and then started to flicker it sounds like the power supply for the led has failed.
What did RCP say when you contacted them?
Old Jun 4, 2019
Yep i did! Strange why its doing that now.
Old Jun 4, 2019
Still waiting to hear back from them!
narindersoi
Dec 1, 2017 08:54 AM
Crescent
Lighting
Jul 28, 2011 05:21 PM
XLR8R
Lighting
Jan 5, 2007 12:13 AM
6th7thGen
Mar 14, 2003 04:04 PM
crazyjetskier
Jan 30, 2002 08:23 PM
