Best Headlight Bulbs
Old May 12, 2015
Nalmonte's Avatar
Nalmonte is an unknown quantity at this point
I have a 2001 Honda Civic ex coupe I recently install 55w/65w Phillips halogens 4500k I believe & I feel they are still not bright enough. Please help
Old May 12, 2015
GolNat's Avatar
Prelude Owner
Re: Best head light bulbs
Silvania Ultrastars are suppose to be nice.
You want a lower color temperature. Maybe a 3500k would be better for you. A higher temp will result in a whiter lighter.
Old May 12, 2015
Stock 99's Avatar
I did some reading about headlight bulbs a while ago and it seems there's marginal difference between bulbs aside from price
http://www.consumerreports.org/cro/m...ulbs/index.htm
Old May 12, 2015
Higher color temp halogen bulbs look cooler, but ultimately are worse for light output. I'd be willing to bet that the 4500k bulbs you have are blue tinted, yes? That blue tint filters out a bit of light, producing a whiter color, but you lose light output. Stick to the 3300-3500k bulbs for optimum output.
Old May 12, 2015
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I used the Philips 9003 XPS2 X-treme Power and found them even better than the Sylvania Ultrastars.
Philips 9003 XPS2 X-treme Power Philips 9003 XPS2 X-treme Power
Old May 14, 2015
carid's Avatar
Former Sponsor
carid is a jewel in the roughcarid is a jewel in the roughcarid is a jewel in the rough
Re: Best Headlight Bulbs
@ Nalmonte
If you are looking for real bright bulbs for your ride, check out the high and low beam headlight replacement bulbs by Sylvania. Take a look at this comparison chart of different light bulb choices based on their brightness: http://www.carid.com/images/sylvania...omparison.html
Check the different series bulbs here: http://www.carid.com/2001-honda-civi...-12611562.html
Old May 21, 2015
Nalmonte's Avatar
Thank you all for your thoughts I will look into it further
Old Sep 13, 2019
0Civic's Avatar
0Civic is an unknown quantity at this point
Well you can use led lights as well according to the tables https://headlightsize.com/honda-civi...acement-guide/
Old Mar 5, 2020
Nur OMoore's Avatar
Nur OMoore is an unknown quantity at this point
Exclamation Re: Best Headlight Bulbs
I also have a 2002 Honda Accord EX-L with an EM2060a 140wh battery & I have it factory equipped with air suspension. Any thoughts about this?
Old Mar 12, 2020
Nur OMoore's Avatar
Great majority of the low mileage Civic's I've kept had this setup & I'm looking to save a few hundred in gas. I was told that the 70/65 did not cut into the catalytic converter unless the mileage dropped from 120,000 to 50,000
civic05acer
Lighting
May 21, 2006 03:01 PM
y.0. KiLLa
Sep 10, 2004 02:24 PM
KalliGarri
May 1, 2004 02:08 AM
untitled
Dec 9, 2002 06:42 PM
mullinad
Jun 6, 2002 01:53 PM
