03 Civic License Plate Light and Reverse Deck on only when trunk open
Old 05-25-2013
nmastereal's Avatar
nmastereal is an unknown quantity at this point
Hey guys back for some more help after a long hiatus.
Just realized recently (cause i got pulled over for them not working) that the license plate light and reverse lights dont turn on like normal. They are off when the trunk is closed but when the trunk is open they are on.
1. I brought it in for a recall months ago (the light harness fix) could they have messed it up? They claim to not have touched anything dealing with it.
2. How could this all of a sudden get reversed?
Thanks in advance guys.
Old 05-25-2013
Re: 03 Civic License Plate Light and Reverse Deck on only when trunk open
Harness has a wire (splice, actually) broken between the trunk hinge and the body.
Here is your DIY and how-to-- linky clicky: http://ww2.justanswer.com/uploads/th...36_A08-094.pdf
You think they are lying to you? NO.
If you actually read about what the headlight switch recall entails, you should realize that recall has absolutely nothing to do with your current complaint.
HTH
Old 05-25-2013
nmastereal's Avatar
Hey thanks! I didn't think they were lying to me based on what was done. Ill check out the DIY thanks!
Old 05-25-2013
It's actually the service bulletin, not a DIY. But it is pretty simple.
Old 05-25-2013
nmastereal's Avatar
yeah definitely
Hrddrvs
04-11-2015 11:22 PM
locozoko
04-06-2002 09:00 PM
SQCivic
11-08-2001 05:56 PM
wawacito
11-05-2001 03:32 PM
sonsonzai
11-04-2001 12:52 PM
Quick Reply: 03 Civic License Plate Light and Reverse Deck on only when trunk open
