Brake Light Problem
Old May 25, 2011
Sailorman3's Avatar
Sailorman3 is an unknown quantity at this point
Brake Light Problem
I have a 05 Civic that has the right side brake light out. Checked the bulb out OK but there is no power going to the socket. Is there a place where that wire will connect to the left side somewhere with a terminal that may be corroded?
Old May 26, 2011
CraigW's Avatar
Re: Brake Light Problem
There would be a junction point... somewhere.
You could tap into the other side brake wiring with a new wire and run it over bypassing the open.
Old Oct 5, 2011
dcove's Avatar
dcove is an unknown quantity at this point
Did iyou ever find the problem with this ? My daughters civic has the same problem. Left and middle work fine but no right and bulb is fine ( replaced it just in case ).
Xuhme
21
Aug 7, 2023 03:40 PM
Poopies
Apr 20, 2017 11:36 PM
trellex
May 24, 2015 04:39 PM
jakeconnor
May 5, 2015 07:30 AM
McD
Apr 29, 2015 03:50 PM
