2002 Right Brake Light Out
Old Oct 5, 2011
dcove's Avatar
dcove is an unknown quantity at this point
Center and left ok, bulb ok. Does anyone know where the junction for these live so I don't have to tear apart unnecessary trunk carpet/panels ?
Old Oct 5, 2011
CraigW's Avatar
Re: 2002 Right Brake Light Out
Double check the bulb, inspect the socket.
Tough to say where junction would be right off hand.
You could tie into the problem side with a new section of jumper wire. (Brake = WHT/BLK) If you did not already know.
And then... run it across the back and tie into the wht/blk on the working side. Or go forward with new jumper and do the same tapping into the high mount wiring.
I suggest soldering connections made.
Old Oct 5, 2011
lazlong's Avatar
Originally Posted by craigw
i suggest soldering connections made.
^^ x2
CarStuff
Dec 6, 2020 12:52 PM
Poopies
Apr 20, 2017 11:36 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
Ma213802
May 18, 2015 07:01 AM
