Bi-Xenon Solenoid Wiring
Old Jun 19, 2010
Just got a quick question.. Been searching around a bit, and I wanna get all my information straightened out before I attempt a bi-xenon retro on my sister's 2010 Fit Sport.
So, on bi-xenon projectors, the bi-xenon solenoid is triggered by a +12VDC signal (high-beam actvation), right?
So... if you're so willing to decipher an electrical diagram, would this work? or is the extra relay to drop the shield excessive, and I could get away with just tapping the shared +12VDC and routing the solenoid ground through the high beam ground, with the diode installed between the high and low beam grounds?
Old Jun 19, 2010
Re: Bi-Xenon Solenoid Wiring
solenoids are very low voltage, just tap directly to the hi beam wiring. you can even tap it if the car had separate hi beams, it uses almost nothing to engage.
Old Jun 19, 2010
cool, cool. Wasn't too sure. I am going to be using an old pair of TYC H4 harnesses, so I'll just connect it directly. Thanks
Old Jun 19, 2010
For semantic's sake, do I have the diode "installed" backwards in the diagram?
Old Jun 20, 2010
ive never had to use a diode with my wiring, so i wouldnt know. but if it doesnt work, simply reverse the diode. power only flows in one direction thru it.
Old Jun 20, 2010
I know. It was just for semantics anyways.
I get bored, make wiring schematics for stuff I'm gonna do/have done.. Just wanna make sure it's functionally correct per the drawing.
I asked my EE major friend and she said she doesn't see anything wrong with it
CBRBlaize
Jun 17, 2016 06:11 PM
sch2cm
Jul 21, 2015 09:58 PM
Jul 12, 2015 11:54 AM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
robbie374
Jul 7, 2015 02:56 AM
