eBay Fog Lights Help
Old Aug 14, 2007
rick1574's Avatar
rick1574 will become famous soon enough
I just installed eBay fog lights, had everything hooked up, good ground and all, and they won't work. I don't have any power to the switch. friend of mine whose got the same car has two plugs that go into the fuse box under the steering wheel, i've only got one. could that be my problem?
Old Aug 14, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: eBay Fog Lights Help
check ur fuses. if they are good. its prolly the relay
Old Aug 14, 2007
rick1574's Avatar
yeah, how many fuses? i just found one and it was good.
how would i test to see if the relay's work?
Old Aug 14, 2007
metalviper's Avatar
i think there was only one inline fuse but i dont remember. uld prolly have to trace the wires to the relay to see what goes where then check if ur gettin power to the relay then see if its engaging when u hit the button, but its more work. it sounds like the same problem i had when installing my ebay fogs, no power at all, so we just cut out the relay completely and it worked. wow its been over a yr since we installed mine
Old Aug 14, 2007
rick1574's Avatar
you cut out the relay and directly connected the two wires? or did you replace the relay. that sounds like it would work, what about the clips going into the fuse box, did you have one or two?
also, would i have to add a fuse in the fuse box for the fog lights?
thanks again for the help, it'd be too easy if these came with instructions...lol.
Old Aug 15, 2007
metalviper's Avatar
ya. theres no relay in my harness but make sure there is an inline fuse if there isnt one already
Old Aug 19, 2007
rick1574's Avatar
yeah there was an inline fuse. the problem is the button wasn't getting power. so i tested all the lines going to the relay (which was good) and determined which one needed power. spliced a power line from the ignition harness into the fog lights and they work like a charm now.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
