HID's in TYC Projectors
Old Apr 16, 2007
amuthini's Avatar
amuthini is an unknown quantity at this point
I want to put H1 HID bulbs into my TYC's. Is there any modification needed to the projectors in order to do this? Or is it nice and easy just like the putting HID's in stock headlamps?
Old Apr 16, 2007
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Re: HID's in TYC Projectors
can't be done, do some searching. The projector is not designed to be used with hid bulbs, you will have to retro fit.
Old Apr 16, 2007
electric130's Avatar
i've seen results pics where people have done it and the light output is worse than with halogens. the focal point of the HID is different than the halogen. horrible hot spots along the edges and hardly any light in the middle of the beam.
Old Apr 16, 2007
silverem2's Avatar
Yes it can. I and many others have done it. Is it worth it? No, but it still can be done.
Links:
https://www.civicforums.com/forums/2...what-bulb.html
https://www.civicforums.com/forums/7...eadlights.html
Old Apr 23, 2007
jay78's Avatar
jay78 is on a distinguished road
dont waste your money on h1 hid kit, save it and do retrofit...
Old Apr 28, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
yes, it can be done. no, dont do it. lol
spend the extra and get do a retrofit. you are going to make a lot of glare over the cutoff that will blind oncoming traffic. check out the forums on hidplanet.com it is by far one of the most informative hid sites i have ever seen. there are DIYs for retrofits for just about every application on there if you search for it.
the good thing a about having the tyc's is that you wont have to do much cutting since it is already designed for a projector. do some measurements to see how big the openings are. there are a lot of people selling hid projectors of all sizes on there for dirt cheap.
Old Apr 28, 2007
only if you do a valeo single beam projector. any other projector is going to require massive cutting. i did a TSX retro into my TYC's and had to chop out a ton of material, design and fabricate my own mounting system, then figure out how to close it all back up. no small feat.
Old Apr 28, 2007
TRIZ's Avatar
WOW, lots of guys forking up info for the OP (orig poster)... I think someone has some rep giving to do.
Old Apr 29, 2007
chawski's Avatar
definately true, but since the tyc has a reflector for high beams, imo a single low beam would be more than sufficient.
do you have any pics of your retrofit?
i dont have any build-up pics, but heres a few shots from mine.
this one is righgt below the cutoff. shows a real nice white
blurry night shot
Old Apr 30, 2007
i was referring to using the valeo low beam as opposed to all other low beam HID's. nothing will fit as easy as the valeo. i've got pics of both my retro and my HID fogs. links to the threads are in my sig.
Old May 11, 2007
seanzee311's Avatar
seanzee311 is an unknown quantity at this point
i wouldn't trade my valeo projectors for anything. I was about to just put in some h1 8000k's into my TYC projectors, but I asked around (some of you actually helped) and ended up going with d2s valeos from an Audi a4 and a 4300k kit, amazing output. I can't imagine ever going back to halogen.
Some downsides.. Install was a pain in the neck, I actually used an iron and a wet shirt to seperate the housing (couldn't use an oven). also, aiming them was a nightmare the projectors are very sensitive to adjustment with the setup I used. Also the cost.. TYC lights, valeos, HID kit, wiring... brought me to about $560 said and done.
Old May 21, 2007
chawski's Avatar
i hear you loud and clear! there is so little room for me. i have a little L shaped screwdriver and even that barely fits. I can only get like 1/16 of a turn before i hit random stuff under the hood. aiming took FOREVER
Old Jun 27, 2007
AzNmiKex215's Avatar
2k1civic.com O. G.
Sure you can install H1 HID's and the beam is fine! Its not as good as "real" HID projectors but its much brighter. And if you aim them properly you will not blind people!
http://smg.photobucket.com/albums/v2...ax215/car/HID/
Pictures in my album
Old Jun 27, 2007
all that, and you have only 1 output pic? and a bad one at that. based on that pic, i wouldn't do it. seriously bad hot spots. we need a pic against a white wall from at least 25 feet away. that pic doesn't show anything.
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
