illuminated toggle switch
Old Aug 29, 2006
corando84's Avatar
corando84 is an unknown quantity at this point
Question illuminated toggle switch
oook, i'm wiring my fogs to an illuminated switch [had regular switch before]
and it asks for a "power, ground, and load" and right now i only got the power (+)and ground (-) wtf is load?
Old Aug 29, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
power is whatever your getting your power from, load is the fogs (in your situation), and ground is ground.
Old Aug 29, 2006
corando84's Avatar
Thanks for quick reply
Old Aug 29, 2006
ya one wire is coming from battery to switch (power), then another from switch to power wire of device (load), then a ground to make the illumination work (ground). the switch will still work with no ground, it just wont light up.
Old Aug 30, 2006
corando84's Avatar
finally got around to doing it, thanks a lot, works perfect now
so basically one prong powers the switch and one powers the fogs?
Old Aug 30, 2006
05reverb's Avatar
when you turn on the switch, it connects the power terminal to the load terminal and to the + side of the led in the switch. the other end of the led is connected to the ground terminal.
Old Aug 30, 2006
ya a switch would be the equivalent of you cutting the power wire and when you want it to turn on, just touch the two sides together. its just a power interrupt so that your fogs dont get constant power and stay on all the time.
MamaBear2015
49
Sep 29, 2015 01:12 PM
mhsmom
Aug 31, 2015 10:45 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
