194 bulb replacement
Old May 27, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
yes, its another bulb replacement question. after searching around, i was unable to find a thread which describes how to replace the circular parking light bulb. i dont have an owners manual, so i cant rtfm.
do you replace it from underneath? take the headlamp assembly out? or do you just have to squeeze your hand in there with the ps fluid reservoir off the bracket out of the way?
Old May 27, 2006
FALKEN's Avatar
Civicforums Junkie
Old May 27, 2006
ctx66's Avatar
Perfect, thank you!
Old May 31, 2006
ctx66's Avatar
I just wanted to add that i used a #168 bulb and it worked perfect. I checked the Philips website, Sylvania website, those computers at walmart, and also had the guy at AAP check their computers, all said #168, not #194. I searched back in earlier threads and some said 194, others 168, so im just throwing in my .02 on that subject.
Old May 31, 2006
CraigW's Avatar
168 is brighter than 194 I think a lot of mfr's are going to 168s. Trade off is it may fail sooner.
#2825 Euro bulbs are the brightest I have seen in the base style.
Old May 31, 2006
i got raybrig 2x hyper clear, it looks like 10w
Old Jun 5, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
wow, i never knew it was that simple to change that little circular light.
it says to push the bulb back in, i thought touching the lense of the bulb will increase chances of blowing out?
Old Jun 5, 2006
thats why you can just use a towel or something. i never touch any bulb even if its low wattage.
Old Jun 5, 2006
depotcivic's Avatar
depotcivic has a spectacular aura aboutdepotcivic has a spectacular aura aboutdepotcivic has a spectacular aura about
WOuldnt LED's put out more light for the replacment of 194/168?
Im thinking about getting some APC amber 194's, should I.
Old Jun 5, 2006
usually no. except i've seen something called velocity led that has 6 led chips and it is way brighter than any bulb. only comes in red tho from v-leds.com or white and blue from autolumination.com
Old Jun 6, 2006
ctx66's Avatar
theyre not halogen so dont worry about touching them. halogens produce much more heat than standard bulbs like these. When the oil from your skin gets on the bulb, it reduces their ability to dissipate heat, as well as creating hot spots on the bulb where the glass can stretch or get warped, and cause the bulb to burst.
Old Jun 6, 2006
a 194 bulb can still burn your skin off, believe me i've tried it
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
thesushiboy
Apr 12, 2015 02:54 AM
0100010
Aug 6, 2008 09:22 PM
Importracer
Nov 17, 2001 03:37 AM
wawacito
Nov 5, 2001 03:32 PM
